Can anyone tell me the year of these seats from the following pictures?
Elvis has left the building.
They look like '72/'73 seats but they don't have the seatback-release lever at the top of the side hinge ... is it on the inside of the seat (nearest to the central tunnel) ?
If so, the driver's & passenger's seats have been swapped.
Andy
Early 911S Reg #753
R Gruppe #105
I think if they have the wire for the seat belt they are for a 73...Ron
Ron
1973.5 911T
1974 BMW R90/6
1986 Carrera, Plan "B"
1987 BMW K100RS Motorsport
2004 BMW X3 6 speed manual transmisson
I think the wire Ron is referring to is for the seatbelt warning - have a look under the seat. If you can see an electrical (usually 'curly') wire then that will also indicate '72/'73 seats.
Andy
Early 911S Reg #753
R Gruppe #105
Thanks, I will check this evening.
Thanks guys. They do appear to be from a '73, since I found a couple of wires and a clip under each seat. I think the wires were blue and white, but don't quote me on that.
Black side plate means 72/73 seat belt warning light was USA only I think but definately only 73
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
My 72 has a seat belt waring sensor also. Just another data point.
Olin - Member #1375
1972 911T
Original
Options added
I've had a couple of '72 T's that I imported from the US & both had the seatbelt warning wires under the seats.
Andy
Early 911S Reg #753
R Gruppe #105
