Thread: Wtb 911 s fender oil cooler
    Hi:
    Searching for the fender mounted cooler for my 1973 carrera rs. Not the trombone cooler, but regular finned cooler.
    RGruppe member 445
    John, I think Stoddard's has them NOS. $$$$$, but NOS....call them...
    Bahia Red '72 911S
    Meerblau PTS 2019 Speedster
    ES #333
    Lightbulb
    John,
    The ones at Stoddard are '69-'71 small radiator type 'small fitting' coolers... and yes, they are quite expensive. All coolers and hard lines '71 and before had small fittings.
    If you want to be period specific, and use period correct hard line for an RS, what you need is a one year only '72 small radiator type 'large fitting' cooler. All external coolers and hard lines from '72 on had the larger fittings...
    There are however work-arounds from small to large fittings with adaptors... any way you go you're looking at a 'bit of change'......
    Over 15 years ago I put a '72 big fitting small radiator cooler with '74 (and later) lines (with the thermostat just ahead of the rear wheel) on my 73S.
    Hope this helps,
    Cheers
    Thanks Stacy and chuck:
    Stoddard wants $4,590.00 new. Chuck's information changes what I need. Thanks, Chuck. That information was very helpful.
    I need to get further into this and try to locate the parts for this new setup.
    If anyone has some of the parts, please give a shout
    RGruppe member 445
  1. WTB: Fender Oil Cooler for 69S
    By rmfent in forum For Sale: 911 Parts
    Last Post: 03-18-2014, 01:06 PM
  2. WTB: 73 S Fender Oil Cooler
    By turbo993 in forum For Sale: 911 Parts
    Last Post: 04-05-2013, 02:15 PM
  3. WTB: 73 S Fender Oil Cooler
    By turbo993 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-04-2013, 07:10 AM
  4. Replies: 8
    Last Post: 09-18-2012, 08:28 PM
  5. FS: S/RS fender oil cooler
    By OliveR in forum For Sale: 911 Parts
    Last Post: 12-01-2011, 02:48 AM
