Results 1 to 2 of 2
Thread: 1971 2.2S No Fuel Help
    Attempted to start up the 71S for the spring and it wouldn't fire. Spark is fine and the fuel pump pressurizes nicely, but still no fuel to the injectors. I took off one of the lines to the injector and nothing was coming out with the ignition on, and with several cranks. MFI belt is in place and turns the pump, but no fuel to the injectors. Any ideas? Thanks Allan
    1974 914 2.0 Yellow/Black
    mfi - no fuel to injectors
    Quote Originally Posted by Gearbox View Post
    allan,
    Did you ever get a reply or figure out the problem?
    regards,
    Al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
  1. 1971 - location of fuel pump/build date question
    By Sean F in forum General Info
    Last Post: 10-17-2013, 07:48 AM
  2. 1971 Electric Fuel Pump
    By my911 in forum Technical Info
    Last Post: 03-21-2012, 12:57 PM
  3. Replies: 9
    Last Post: 11-01-2010, 10:12 AM
  4. 1971 911S MFI Fuel Pressure?
    Last Post: 05-05-2009, 05:41 AM
  5. 1971 911S fuel problem?
    By go fstr in forum Technical Info
    Last Post: 11-20-2006, 05:42 AM
