Thread: Turn signal does not turn off once I make turn?
    Any thoughts???
    Jan 2003
    NW Indiana
    Is there a cancel ring on the back of the steering wheel? Even if there is one make sure it isn't bent. Sometimes these are bent and won't make contact with the cancel switch on the turn signal, or the turn signal switch itself is loose so that it won't touch the cancel ring.
    Brian
    '71T
    R Gruppe #299
    The cancelation is controled by tiny springs (if you remove the steering wheel you'll see them. If this is a new problem, the springs might have broken
    Henry
  1. WTB: Turn Signal Switch
    By rajaro in forum For Sale: 911 Parts
    Last Post: 12-31-2012, 05:59 PM
  2. FS - NOS SWB Turn Signal Assembly
    By tom1394racing in forum For Sale: 911 Parts
    Last Post: 04-02-2012, 05:44 AM
  3. FS: Turn Signal Switch SWB 911/912 65 -67
    By 67softwindow in forum For Sale: 911 Parts
    Last Post: 01-02-2009, 06:56 PM
  4. 69 turn signal switch, left turn works, right doesn't
    By caproader in forum Technical Info
    Last Post: 06-04-2008, 05:30 AM
  5. Turn Signal Housings
    By Paul Schooley in forum General Info
    Last Post: 03-20-2006, 04:31 PM
