Ok just as the title says I have a 1973 911t 2.4l engine.
serial number 6134438. 7R case
I did a cold leak down test on the engine not long ago and non of them cylinders were more that 8% leak down.
The original fuel injection for this engine has been removed and some weber carbs with k&n air filter have replaced it.
Everything from the clutch to the alternator and from the heat exchangers to the air filter, also the ignition box and fuel lines and pump (everything that should be needed) comes with the engine.
The engine did run very well when taken out of the car, it was upgraded for a 3.6it does leak a little bit of oil which looks to only be coming from the valve cover gaskets
The price is $4000 obo shipped. I live on the east side of the twin cities of Minnesota and my zip codes is 55125. I do work at a dealership and if it is sent from a buisness to a buisness it is cheaper.
Thanks for looking
message, call, or e mail if any questions
651-245-4884, lowridr83@comcast.net
Ben
