Results 1 to 10 of 18
Thread: 15 vs 16 mm rear anti-sway bar
    Ol' Ivory (early '67 911s) came equipped with a 15 mm rear anti-sway bar. The Rust Bucket, also a '67 911S, came with a 16 mm rear anti-sway bar. What would be the advantage of one size versus the other handling wise? Which would be preferable for a street stock 2.0 '67 911S?
    Thanks!
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Stiffer(bigger) rear bar gives more oversteer tendancy.
    You have to make the call based on driving style. Torsion bar stiffness goes up by diameter^4 so a 1 mm difference can be felt is a more lively car through the turns. The car wants to rotate quicker.
    Agreed on the vehicle dynamics. A big bar on the front, increases rear lateral and motive traction. A big bar on the rear, increases front lateral and motive traction.
    We all know that Porsche struggled with the SWB 911 handling, which ultimately led to the development of the LWB. Ol' Ivory is 305764S and the Rust Bucket is 306066S, both '67 911S. Was the change from 15 to 16 mm a permanent change in the SWB 911S? Or was this a "parts bin" availibility issue?
    - Neil
    If you have too much rear bar you hit the wall backward. Too little you hit the wall forward. Simple.
    15mm to 16mm at the rear, on a street car, will barely be noticeable...just a tad more oversteer. And if you're not going thru your neighborhood at 60mph over the speed limit, it will never affect you one way or another. 18 or 20mm on the other hand would be a noticeable change.
    jhtaylor
    santa barbara
    waht size bar do you have in front are your torsion bars stock?
    Apr 2004
    Porsche recommended :
    Curcuit racing : 16 F and R
    Hill Climb : 14 F / 16 R (let that back end go !)
    Rallies : 15 F / 16 R - that was also stock ' 67 911S.
    Also recommended that the ride height be adjusted according to the type of use.
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Apr 2004
    Oh, and musn't forget:
    The Normal had only a front , 13 mm bar, which more than a few auto x drivers prefer as a set up.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    I have 15 for the front and an 18 rear. Is the 18 way too much for street?
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Apr 2004
    Depends on how much of the road you like to take up....
    Curcuit racing is closest perhaps to spirited road runs and there the factory recs. 16.
    Stock also being 16 I would guess ( I've never tried it ) 18 seems like it would be excessive
    What size tires do you run ?
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
  1. FS: Smart Racing Products Front Anti-Roll / sway bar
    By duktail in forum For Sale: 911 Parts
    Last Post: 12-30-2013, 06:37 PM
  2. FS: @Samba - Rear original anti sway bar mounts
    By Cliff in forum For Sale: 911 Parts
    Last Post: 12-29-2012, 05:22 PM
  3. WTB: RSR anti sway bar arms
    By Mike_Moore in forum For Sale: 911 Parts
    Last Post: 11-25-2008, 09:20 AM
  4. FS: Early anti-sway bars
    Last Post: 04-28-2008, 05:34 PM
