Thread: European gauge question
    Mar 2006
    Louisville KY
    I have a weird Speedo it is in KM but has the 356 style red part on the dial. It came from a 912 as the tach has the same style. Both are date stamped 3.66. I guess my question is did all european 912's have this style gauges? I think from the date stamp that it would be to late to be from a three gauge 912. Any body have any ideas?
    Tony Proasi
    52 split window coupe
    Euro Speedo
    Hi Tony,
    The red lines at 50km on your speedo is to remind you of the speed limit in most European towns and cities. Every Euro spec speedo I've seen has had them.
    Hope this helps.
    All the best!
    Roger Grago
    R Gruppe #27
    Early 911S Registry #194 since 1999
    this may sound silly but I always thought that was the minimum speed you could pop it into top gear.
  1. Wiring question / oil level gauge
    By ze german in forum Technical Info
    Last Post: 01-12-2013, 12:56 AM
  2. Euro/ROW Gauge Question
    By Fishcop in forum Technical Info
    Last Post: 01-18-2012, 11:46 PM
  3. Another Outside Temperature Gauge Question
    By hdavis in forum General Info
    Last Post: 12-16-2008, 08:44 AM
  4. Question on gauge brightness
    By kilodawg in forum Technical Info
    Last Post: 01-20-2007, 03:44 PM
