Thread: 65/66 Nadella Half Shaft
    Asking how much these are worth......
    65/66 Nadella Half Shaft Complete with trans stub axle
    PM, post, or email direct
    eprpimm@aol.com
    Here is some info about it. FYI:
    "Nadella halfshafts were only used on '65 and '66 911s and 912s (starting in 1967 the halfshafts were designed for constant velocity joints). The output flanges coupling the transaxle to the Nadellas are a unique design, with a keyway and different bolting pattern.
    Some potential advantages of Nadellas are:
    1) They can withstand high amounts of torque. They were also used on the 904 and 906 racecars.
    2) The joints are sealed.
    3) If you're a concours person, perhaps you can score extra points for originality.
    Some potential disadvantages of Nadellas are:
    1) They are not constant velocity.
    2) The lower joint is exposed to the weather, has no dust boot, and once it starts to wear out the Nadella is not easily rebuilt.
    3) The integral mechanism to allow axial movement is not symmetric, so when extended they may not be in balance, which could create extra vibrations.
    To install a later transaxle with output flanges for CV joints into a 912 with Nadellas, or to convert from Nadellas to CVs, you'll need to assembly all the bits and pieces. CVs, half-shafts, and splined shafts to the wheels.
    The 912 Registry Webmeister changed from a 4-speed to a 5-speed in his '68 912 Targa, an easy choice since CVs were original equipment. He prefers this combination; smoother, and easier to climb grades. But he has kept his '66 original; it only needed a rebuilt Nadella for the driver's side, and the full conversion to CVs would cost $$$.
    New Nadellas have not been available for many years, and Nadellas with the joints in good condition are valuable, so if you decide to upgrade, don't discard the Nadellas, consider selling them to another '65-'66 owner, or a 904 or 906 racer! "
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    They were also standard on the 67 911S equipped with limited slip. Usually they come up on ebay every few weeks and sell for about $100 to $150 each. I've seen some that have flanged fittings as well as the knuckle fittings.
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    Sold for $125, thanks for input
  1. FS: @leboncoin.fr - Nadella half shafts for '64 and '65 911 in France
    By kouwenhoven in forum For Sale: 911 Parts
    Last Post: 11-28-2013, 01:29 AM
  2. Nadella Half Shaft Needle Bearing
    By Brad Davis in forum Technical Info
    Last Post: 07-03-2013, 04:55 AM
  3. Strange Nadella Half-Shafts?
    By Fishcop in forum Technical Info
    Last Post: 06-22-2013, 05:29 PM
  4. early 911/912 half shaft history?
    By adam912 in forum Technical Info
    Last Post: 07-15-2011, 01:00 AM
  5. Nadella Half Shafts (axels) for SWB LSD
    By Rennman in forum For Sale: 911 Parts
    Last Post: 07-29-2010, 08:19 PM
