Thread: Correct door hinge bolts for ´73
    My ´73 (first reg. 10/72) has lost it´s original door hinge bolts.
    I´ve searched this site, but found no definitive info about correct ones.
    It was said that the bolts changed mid-72, earlier type being 12-corner type.
    Any info / pics of the newer type bolts?
    Mika
    1973 911T targa (9113510254)
    signal yellow & black
    M409 sportseats leatherette & corduroy
    M424 fuel tank 85 l with emergency tire
    M470 comfort equipment
    M473 front bumper steel with spoiler
    have a look at the porsche spare parts catalogue.
    Should be normal M8 hexagonal head.
    andreas
    Yes, evidently the type of bolt changed mid-72. I have both an early (600 something 72) and a late (1440 something 72) and the bolts are different, early has the 12 pt internal hex and the later one the hex head cap screw. There is a difference in the hinge itself which will tell you what you need. If the bolt hole on the hinge is counterbored you use the 12 pt internal hex, if not counterbored then it uses the standard hex cap screw.
    May 2006
    CT
    '72 and earlier used an M8X15 pan head (internal hex)
    '73 and later used the M8X15 hex.
    Here's a pic of my '73 with the hex.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Great info, thank you guys!
    The hinges in mine are flat (not counterbored), so it´ll be M8x15´s then...
    Many thank´s again, this is a GREAT place
    Mika
  1. FS: Five door hinge bolts from a 71T
    By fourteenten in forum For Sale: 911 Parts
    Last Post: 07-02-2015, 07:55 AM
  2. FS: Door hinge bolts
    Last Post: 10-23-2013, 06:42 AM
  3. WTB: Door hinge bolts
    By Rino71 in forum For Sale: 911 Parts
    Last Post: 05-09-2013, 05:35 AM
  4. WTB: Door hinge bolts
    By Rino71 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 05-08-2013, 08:58 AM
  5. W T B door hinge bolts
    By edmayo in forum For Sale: 911 Parts
    Last Post: 10-28-2008, 06:32 PM
