Thread: Info on unstamped engine case 901 105 111 1R
    Senior Member hgarazo's Avatar
    Jan 2004
    Frederick, MD
    I need some help figuring out what this came from. I did a search and was unsuccessful.
    It's currently in a 2.7 configuration in a 1970 T/RS clone. The fan says "901 106 101 5R". I looked where the engine number is supposed to be and it's blank. I did not look at the case halves yet.
    Thanks for your assistance!
    Henry Garazo
    '68 Polo Red 911L Barn Find
    '70T 2.7 Coupe
    '58 1600S T2-A Speedster
    '87 Triple Black Carrera Coupe
    "Form Follows Function"
    Early 911S Registry #962
    Potomac Region PCA
    Sounds like a replacement case for a 1969 car.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Jan 2004
    Frederick, MD
    Crawled under and looked tonight.
    The engine crankcase # is 901 101 101 7R and 901 101 102 7R. The other numbers are I first mentioned are above the valve covers.
    I saw a number on one of the bottom rear ribs on one case half - 11 83
    The engine number area is unstamped, and I could not find another number on the horizontal segment just posterior to this area (or anterior with regard to the car)
    Sounds like a replacement 7R mag case 2.7 engine?
    Henry Garazo
    '70T 2.7 Coupe
    Potomac Region PCA
    Quote Originally Posted by hgarazo View Post
    I'd say so. THE best factory Mag case "out of the box," and a replacment one..with the right stamps it can be (almost) "original" ..to your car!
    -Allen-
  1. FS ; 2.7 Unstamped Engine Case
    Last Post: 08-23-2011, 03:50 PM
  2. unstamped case
    By frank edwards in forum Technical Info
    Last Post: 04-20-2007, 07:09 PM
