Thread: Gearbox lube:
    Gearbox lube:
    Has anyone used GL-5? I've been told a slight whine in 5th (915 gearbox) might be helped with using this. Any thoughts? I've always heard good things about Swepco.
    Jack
    Jack Griffin
    Dallas, Tx.
    Early 911S #167
    RGruppe #192
    '55 356 s/r Outlaw
    '70 914-6 (2.5L owned since '76)
    '85 911 Carrera Cpe.
    '89 911 Speedster (bought new)
    '84 MB 300CD (bought new)
    Gone but great memories - '74 RSR 9114609113
    Apr 2003
    Portland, OR
    No clue about GL-5 oil in general but SWEPCO 201 is the stuff you want.
    Per the Bird BBS Site:
    "Multi-purpose gear lubricant for most manual gear boxes, stationary industrial or rolling stock. Features API GL-5 and MT-1 rated lubricant. Exceeds military specifications MIL-PRF-2105E. Oxidation, rust and corrosion inhibitors. Anti-catalyst and anti-foam inhibitor. Anti-wear inhibitors and extreme pressure (EP) additive. Adhesive/cohesive characteristics for climbing action. Pour point depressant. Limited slip characteristics. Reduces gear oil consumption as much as 50-75%. Improves equipment performance life, drops operating temperatures 8-18% (29-72øF or 0-22øC). Decreases unscheduled downtime. High temperature stability for outstanding wear control and cleanliness. Energy savings (electrical/fuel). Primary Markets are Construction, Dairies (milk processing), Crane and crane rental operations, Post offices and Local trucking. Industrial gear boxes, Standard shift transmissions and differentials."
    Harry
    Member #789
    2009 MB C300
    Kendall GL-5 80/90
    John Walker recomends Kendall GL-5 80/90
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Api gl-5
    Here's the basic spec (section 3.3):
    http://www.api.org/certifications/en...pload/1560.pdf
    Here are the details in the referenced ASTM Publication STP-512A:
    http://books.google.com/books?id=ykX...sult&resnum=10
    You most likely already have a GL-5 gear lube in your transmission. The whine could be an indicator of some required maintenance. That being said, a oil change cannot hurt to try.
    Peter Kane
    '72 911S Targa
    Royal Purple max gear oil 75w/90 Works alot better then Swepco
  1. FS: center lube cam boxes
    By geneulm in forum For Sale: 911 Parts
    Last Post: 05-24-2013, 05:55 PM
  2. FS; center lube cams
    By otto in forum For Sale: 911 Parts
    Last Post: 05-10-2012, 12:12 PM
  3. Gibbs lube - anyone used it ?
    Last Post: 10-06-2009, 06:27 AM
  4. gearbox lube question-
    By tims911s in forum Technical Info
    Last Post: 09-07-2009, 03:50 PM
  5. 911-01 gearbox with LSD: wich gear lube ?
    By zaza in forum Technical Info
    Last Post: 08-11-2005, 10:34 AM
