Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Driving along and POW!!!
    I was out for a drive this am, and all was good for about an hour or so.
    Then, upon exiting a 25 mph residential area, I wound it out in 2nd gear to about 5K, and shifted to 3rd gear. Upon shifting into 3rd gear there was a loud backfire, a cloud of black smoke out the rear, and the engine cut out.
    It cranks strong but won't start.
    I walked home, got the wife, her Lexus, and a rope to tow it home.
    2.4 with MFI, Blue Permatune Ignitor. Other than a very occasional backfire with black smoke when letting off the gas, it runs flawlessly.
    Any ideas on what the most likley cause of the no-start issue is?
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Check the trigger wire to the dizzy
    I've had that come off under acceleration before. Bob
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
    Frank,
    After you fix the "no-start" issue, I recommend the following thread for eliminating the backfiring:
    http://forums.pelicanparts.com/showt...hreadid=160057
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Oct 2005
    Minneapolis, MN
    Check the CD box....
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    In addition to checking the trigger wire, I'd inspect the magnet wheel on the distributor shaft. I've seen ONE that came apart, spit out the magnets out of place and have the same problem you're having ... it was an elusive problem because it wasn't obvious. You may need to take the distributor out and inspect it on the bench.
    -Marco
    TLG Auto: Website
    Ignition Coil?
    Thank you all for the advice.
    I was thinking.....could it be as simple as a bad ignition coil? The current bosch unit is nearly 4years old. How long do they typically last? Any tell-tale signs as they go bad or do they simply quit?
    I had a 356C coupe about 5 years ago that just shut down without warning while stopped at a traffic light. I had the car towed to the shop on a flatbed; and low and behold, the coil was bad.
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Aug 2007
    Phila Pa. area
    coil
    They basicilly never go bad except when they go bad? My experience is they go bad when they heat up, then they might work when they cool down. Also the Tack can cause electrical problems sometimes. Might want to disconnect the purple and black wire at the distributor. Electric problems, always hard to figure.
    Senior Member 72tii's Avatar
    Nov 2004
    Bedford, TX
    Quote Originally Posted by FL-Frank View Post
    If it's one of the silver Bosch coils that are made in Brazil, you might be on to something. The silver ones have a bad habit of breaking down especially under heat. Do you still have the original short black factory Bosch coil? It would be an easy thing to change out just to eliminate the coil.
    1968 911 #11830241
    Early S Registry #810
    R Gruppe #461
    Quote Originally Posted by 72tii View Post
    HI Mike,
    Yes, it's the Brazilian silver coil. Unfortunately, I don't have the original factory part.
    I just pulled the coil wire from the distributor cap, taped the end about 1/4" from metal, and cranked the engine. Result - NO SPARK. So, that probably means it's the coil, correct?
    What's the best replacement part to get? Another Brazilian silver one like Pelican sells? Or?
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    HI Mike,
    No, do not get another silver one, they are crap, crap, crap. You would be far better off finding a used black one, either made in Germany or Spain, both are FINE. And they are pretty easy to find.
    Bahia Red '72 911S
    Meerblau PTS 2019 Speedster
    ES #333
  1. It's All About the Driving
    Last Post: 11-24-2013, 10:26 AM
  2. Driving Shoes where to buy
    By TZombek in forum Off Topic
    Last Post: 08-14-2013, 01:06 PM
  3. Ice Driving
    Last Post: 11-16-2009, 04:18 AM
  4. Driving 'Em
    Last Post: 12-07-2005, 09:52 AM
  5. driving my T
    By joelrkaplan in forum General Info
    Last Post: 03-11-2004, 06:59 AM
