Results 1 to 8 of 8
Thread: Rookie Carb Adjustments
    May 2009
    T County, Ohio
    So here goes. New 911 owner here,
    http://www.early911sregistry.org/for...ad.php?t=27688
    I have been sorting a 69 T with Webbers. Cleaned the tank, bushings in the pedals, rebuilt calipers, changed oil. It's running good, but I am now to the carbs. I have rebuild kits coming from Stoddards. It's running, but I have a feeling (feeling?) it should be running better.
    I finally turned the mixture screws all the way in, counting as I went, seated them and turned them back out. It seemed to run smother, maybe imagination.
    This is all I have done. My question is, how would one proceed with these things. I know I need a syncronizer, but can I make some basic adjustments without taking them apart and cleaning them first? Maybe links to some good threads? I probably better do some searching, I was just looking for some very basic info. Hows that old book the Pelican sells? Whats the worst that can happen when I start turning them screws?
    69 911 T #100176 Sportomatic
    Vanagons, 97 Jetta VR6, Misc junk...
    1-Check throttle shafts for play. no tuning if too much play. Get up with Paul Abbott at performanceoriented.com if you have this problem.
    2-Set linkages and throttle cam/WOT.
    3-Get synchronizer thingy and start going through the usual process. I posted a link to a great write up on this in the 'all time best tech threads' thread.
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    worst that can happen is you burn a hole in one or more pistons driving a severely out of tune car.
    Erik
    Early S # 1107
    forgot the VERY first step;
    -set timing/points gap and do valve adjustment.
    Erik
    Early S # 1107
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    I think this thread covers it pretty well....
    http://forums.pelicanparts.com/showt...rbin+and+weber
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    I can loan you my synchrometer.I'm in Medina
    May 2009
    T County, Ohio
    Thanks guys, now just have to get to it!
    I have set the points. I pulled the distributor to get it timed AND be able to snap the cap clamps. It didn't seem right. I had to adjust the timing to get it started. Fired right up.
    I have not adjusted the valves yet, oh boy, I better get to that!
    Thanks again for the links and I promise to SEARCH!
    And thanks for the synchrometer offer. i will most likley get my own soon, seems like it would be almost mandatory owning this car.
    By the way, whats with the Italian sh....stuff?
    Also a "whats wrong with this picture" picture (brakes)....yea thats right, not enough pistons, slight ordering mistake. I got them all new now though.
    Dan
    Member cmoanz's Avatar
    Nov 2008
    Plainfield, IL
    Good news bad news
    Good news is that Supertec Performance or other sources can build you a Bosch distro replacement ($600ish) for your Marelli, bad news is that you have a Marelli where the parts supply is limited to non-existent.
  1. FS: 46 mm Weber Carb set up
    By vintage 911 in forum For Sale: 911 Parts
    Last Post: 01-12-2014, 10:24 AM
  2. Weber idle adjustments
    By 1QuickS in forum Technical Info
    Last Post: 01-20-2011, 02:53 PM
  3. Rookie accelerator pedal question
    By Zuffenhausen in forum Technical Info
    Last Post: 01-16-2011, 06:36 PM
  4. Early 911S Rookie Needs Torque Specs
    By Bob Schaefer in forum Technical Info
    Last Post: 05-08-2004, 06:22 AM
