Thread: 1967 911S CORRECT Ignition Lock
    OK all you experts.
    What was the correct ignition lock on a US delivery 911S Coupe? Was it a non-locking column with a #300 series key, or was it a locking column with a #700 series key? Or, did they make a non-locking with a #700 series key???
    Thanks for the input!
    Seattle WA
    Quote Originally Posted by jwillhoit View Post
    OK all you experts.
    My coupes are the shorter key, Silca POR2 non locking, my targas are the longer Key, Silca POR5 non locking. I have a Euro coupe and I can't remember whether it's locking or non, or what kind of key but the insert pad has a spring loaded 1/2 inch diameter plunger that you must push the key against in order to turn it (from memory...).
    Eric
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    My Euro S has a steering locking, My Normale does not. Both use the same kind of keys (courtesy of my local locksmith)
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    Thanks for the help. I was told that US 67s did not have a locking column. No I have another question: I have two keys. One fits the ignition (a #300 series) and one fits the doors and the glove box (a FL #700 series). Is this the correct set up? I understand that the valet key should not fit the glove box...is that correct?
    Thanks for the help!
    For those following this thread:
    It ends up that the FL key is longer and was used on the locking columns. The doors could either use this key or the 300 series key. The glove box always had a different key.
    Jul 2004
    Sutalle, Ga.
    When I had both of my cars rekeyed the locksmith needed to use a seperate key for the glovebox. He said it had an extra pin in it. May have something to do with the original valet key. I used all new (one size) key blanks for everything. So two keys (one that fits both ignition and doors) and one for the glove box only.
    Bill
    Currently:
    67S Concours King
    68 912 Flipper
    83 911SC
    93 Mo30 968
    R Gruppe # 551
  1. Correct carpet for 1967 911S Targa
    By jerryg in forum Technical Info
    Last Post: 11-26-2013, 03:39 PM
  2. ignition lock removal problem
    By RSTarga in forum Technical Info
    Last Post: 12-31-2010, 05:06 PM
  3. Ignition Lock ?
    By lwalwa in forum Technical Info
    Last Post: 10-09-2009, 08:06 PM
  4. Anyone has pic of correct 1967 911S owners manual
    By EARLY911ZOO in forum General Info
    Last Post: 05-04-2007, 06:05 PM
  5. Key for ignition/door lock
    By 911pcars in forum General Info
    Last Post: 06-12-2006, 05:18 PM
