Results 1 to 2 of 2
Thread: Weber Jet settings for 71T ex UK car
    Senior Member Andy B's Avatar
    Feb 2005
    Near Bondi Beach, Sydney Australia
    Hi guys I've had problems with my 911T 1971 model not idling properly, but is great above 3000rpm.
    After much consideration checking other basic facts we have just pulled the Weber's off and found what we think are incorrect jets and modified emulsion tubes. The Webers have the following identification:
    40 IDTP13C (with 5107 below) and
    40 IDTP13C1 (with 5232 below)
    Can someone suggest the correct factory sizes for:
    Venture =
    Main =
    Idle =
    Air =
    E-tubes =
    and who they can bought from ? Finally if there is a source that this information is freely available from ????
    Thanks in advance.
    Andrew B (Tiger)
    911 69E Historic Production Race Car
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Tiger
    As per TYP901 post original specs are:
    Original 2.2T specs are:
    Venturis 27mm
    Preatomiser 4.5
    Main jet 110
    Air corrector 185
    Emulsion tube F1
    Idle jet 45
    Pump jet 50
    Idle air bleed 145
    Float needle valve 1.75
    I probably have some of this stuff in my stash if you need it.
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
  1. Koni red settings on a 67S
    By Bill Meyer in forum Technical Info
    Last Post: 03-21-2007, 12:38 PM
  2. Cam Timing Settings
    By 1969-911Targa in forum Technical Info
    Last Post: 02-02-2007, 12:14 PM
  3. suspension settings?
    By james in forum Technical Info
    Last Post: 06-17-2006, 11:12 AM
  4. MFI Butterfly Settings
    By domtoni in forum Technical Info
    Last Post: 08-02-2005, 05:15 AM
  5. suspension settings
    By scargo70 in forum Technical Info
    Last Post: 04-07-2004, 06:41 PM
