Results 1 to 7 of 7
Thread: Maximum Wattage for Cibies?
    Port Macquarie, Australia
    Hi All
    I've just wired up my Cibie hood lights through a relay and am wondering what wattage I can safely run?
    I do some country driving and would like to run these spotlights with as high a wattage as possible, maybe 100w (120w blow too easily on our bumpy roads). I'm happy the all new 40A wiring is up for it - currently running 55w and have the original '69 Marchal alternator (I suspect this will be the weakest link?).
    I'd appreciate any advice/experience/reference.
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
    Jun 2005
    Perth WA
    I run 100w through mine with no problems, so far. (unlike my engine !)
    Michael
    Thanks Jappy. I've decided I'll go with the 100w globes and see how I go.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Same on mine John
    I can't say I've run them for any great length of time though!
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    John,
    Can you show some photos and details on how your wired up the Cibies?
    I have yet to wire mine up and always looking to see how others have faired.
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    Cibies
    Interestingly Cibie published an article many years ago (Late Seventies) which dealt with uprating the bulbs in Oscars and Super Oscars.
    I am sure I have a copy in an old magazine but it is up in the attic and may need some finding.
    The basis of the article was that the reflector was only designed to deal with a certain light ouput and fitting a more highly rated bulb only marginally improved output.
    The calculations on reflector area and bulb position were given and from memory a 100W bulb in an Oscar gave 2% more candlepower output than
    55W.
    Hi Chris and Max, my apologies, I hadn't checked this thread for a little while.
    I do recall something about efficiency not being too much better with 100w, but I figure it can't hurt to check it out...
    To wire them up I found a correct single stage fog light switch and put it in the dash in a blank hole next to the cigarette lighter (probably where the fog light switch goes?). I used a hella relay and located it next to my fuses and tapped power in directly off the battery. The relay is switched off the left high beam wire, but the relay safely feeds both Cibies. I powered the switch light off a tap to the high beam indicator at the speedometer so everything lights up and displays correctly I drilled the hood lid rib and put in a wiring grommet so that the wire is hidden inside the hood rib and runs from the hood lights, down to the hinge and then is again hidden in the wiring loom running back to the fuse boxes at the front. Overall I'm very pleased with every visible component looking factory and period correct...
    I'll add some photos shortly.
    John Forcier
    EarlyS #1987
    Restoration Saga
  1. Replies: 3
    Last Post: 11-09-2010, 02:09 AM
  2. Maximum Speeds
    Last Post: 10-19-2007, 05:34 PM
  3. Maximum HP from a 911s 1971
    By Aus911s in forum Technical Info
    Last Post: 05-29-2003, 09:33 AM
