Thread: 1966 brake switch
    1966 brake switch
    Having brake light problems...Where is the brake light switch located on a 1966? Thanks.
    Sep 2006
    La Quinta
    It's under the floor board at the base of the brake pedal.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    The brake light switch on a '66 is screwed through a banjo bolt into the side of the master cylinder. It is accessed from under the car by removing the protection plate.
    Here is one of Leon Kreger's photos showing the switch.
    Sep 2006
    La Quinta
    Opps...Thanks John. I was thinking of my 914.
    Registry #983
    R Gruppe #741
    Thank you John...It's appreciated.
    A man never stands so tall. . . as when laying on his back to help a SWB 911!
    John, no apology ever necessary-- the 914 and darned near every other car uses the switch in the pedal cluster--- once at a club race a guy in my class came up and told me "you don't have any brake lights" and I pulled off the floorboard, blew the spider webs out of the switch and the lights came back!
  1. Park brake switch
    By motogman in forum Technical Info
    Last Post: 04-13-2013, 07:36 PM
  2. Brake light switch supplier
    By hdavis in forum General Info
    Last Post: 11-13-2010, 08:37 AM
  3. Correct brake light switch
    By Strato 102 in forum Technical Info
    Last Post: 09-09-2009, 12:00 AM
  4. Hand Brake Switch - light
    By drwhosc in forum Technical Info
    Last Post: 07-27-2009, 05:47 AM
  5. brake light switch
    By jkolesa in forum Technical Info
    Last Post: 04-10-2009, 03:57 PM
