Thread: Help.... My glove box door is jammed..
    Senior Member Macroni's Avatar
    Nov 2006
    Philadelphia PA
    I have a 1973 T.
    The original key has never been able to lock or unlock the glove box. Today, I can not get the box open. I do not know if it is the lock or if it is just jammed. Though it does not seem jammed. Not a crisis but given the contents I need to eventually open. How do I get in? Remove the knee bar and unscrew the door? Locksmith? I do not want to create unnecessary damage.
    This must be a security feature I never heard about; clear 120mph and the glove box automatically locks!
    86 Sport Purpose Carrera "O4"
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Glovebox stuck!
    Might be able to take the box out after removing the strap that holds it in place, & unscrew the lock retaining bolt and or, depress the release button to open the door..
    I've actually had this happen to me on my 73'S! You have to unbolt the knee pad (not to hard, just get a 8mm socket with a small extension). Then you need to get a small punch and punch the pin out of the hinge (yes, this hinge is very thin and long, but just knock it out just far enough so you can get a grip on the hinge with a pair of pliers. Once you grip the hinge with a pair of pliers knock the pliers with a hammer and the whole pin should come out.
    Nov 2006
    Philadelphia PA
    Thanks.....
    Aug 2005
    VA
    Before you start taking things appart. Try turning it really hard. Happend to me once and I was able to get it open in his manner. The whole mechanism will turn (if it is like mine) and not the little catch.
    Good luck
    Chris
    73 911 E
    Happened on my 74. I actually had to cut the metal strap holding the glove box in. Then I could remove the box and reach the lock at the back. Repaired the strap with 4 pop rivets and a 2" x 1/2" strip of thin aluminum.
    jhtaylor
    santa barbara
  1. WTB: 73 Glove box door
    Last Post: 02-21-2014, 10:42 AM
  2. FS '72 glove box door, glove box & aluminum dash trim
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 12-10-2012, 11:59 AM
  3. FS: 73 Glove box door
    Last Post: 09-28-2011, 06:42 PM
  4. FS - Glove box door '67
    By tom1394racing in forum For Sale: 911 Parts
    Last Post: 02-08-2008, 04:58 PM
  5. FS - Glove box door 69E
    Last Post: 02-08-2008, 04:53 PM
