Results 1 to 10 of 14
Thread: Front license plate help?
    Hello
    I have acquired a pair of license plate mounting brackets as RI requires a front plate to pass inspection. It's a shame since the car does not appear to have ever had front plates before.
    I don't quite understand how these attach etc. Can someone post a picture or two of an early car with front plate? Non S bumper, of course.
    Thanks!
    Dan
    Sep 2006
    Eagle, Idaho
    Here's a photo of the most attractive and "Porsche-esque" installation I've seen to date.
    Regards,
    JZG
    That is essentially what I have ( see post #9 in this thread). Brackets available from Stoddard. Because you cannot easily access the area with the bumper mounted to install nuts, you either need to use sheet metal screws OR make square holes and use the square plastic inserts that accept sheet metal screws available from you local auto parts store. I used the inserts because of the fiberglass bumper.
    Dec 2004
    Front plate mounting solution?
    Granted it's not the most handsome solution but it is very functional and requires no drilling into any part of the car.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Dec 2004
    Side view of mount
    Sorry, forgot to add the second view. This view shows the small tabs that rest agains the cross brace of the underside of the car to prevent it from shifting side to side.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    if it is just for the inspection and you will take them off after and you have a virgin bumper then how about some sticky tape for a temp solution
    then after the inspection off with the plate
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Front plate
    I had a friend who scanned my plate into his sign making computer and it spit out an exact copy on 3M reflective vinyl. I then applied it to the lower front bumper like a large bumper sticker. I have never had a problem with inspections or the police.
    Joe
    Joe
    1973 911 2.7mfi
    Early 911 Registry member #759
    RGruppe #499
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Sacto, love that solution. Did you fab that? Are there any detailed drawings? Care to make another?
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    This is where I ended up. I used a bracket from a later car (924?) , and attached it to the front bumper through holes I drilled. This was a bummer for the bumper, but it had an assortment of holes anyway (which the plate covers up). I used to have the brackets pictured in early posts of this thread, but my front plate would scrape on diveways regularly. The plate mounted at the angle never scrapes, even though I have lowered the ride height. I wasn't going to scrape up my restored plates with the vertical bracket!
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Quote Originally Posted by Neunelfer View Post
    +1. I have some repro German Plates that I want to mount on the car and be able to easily remove the CA yellow on black plates used for driving when I go to display it.
  1. FS: NOS front license plate mount
    By typ901 in forum For Sale: 911 Parts
    Last Post: 11-30-2014, 10:48 PM
  2. WTB: Front License Plate bracket
    By BrentF in forum For Sale: 911 Parts
    Last Post: 04-20-2013, 09:50 AM
  3. FS Front license plate braket
    Last Post: 03-21-2011, 11:11 AM
  4. front license plate
    By Dave Pugh in forum General Info
    Last Post: 05-28-2010, 09:42 AM
  5. FS: Front License Plate Mounting Kit
    Last Post: 09-02-2009, 07:05 AM
