Thread: Season Storage Ideas
    Now that the weather has turned bad (Austin not LA) and we can no longer drive our cars please offer up your long term storage ideas
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Ostentatious??
    Just drive at night or early morning.
    Its still a 100 degrees at 10pm and pushing 90 at 9AM
    ow! should be in the 90s in daytime and down to 70 at night, but...
    fill the tank with fresh ags; change the oil and let it sit on a battery float type maintainer
    there is more on Pelican if you use the search terms long + storage
    but most is based on cold weather (i.e. condensation, etc.)
    My Plan
    a good wash and wax careful with the water
    fill the tank/add Staybil
    a good run and change the oil/filter
    ad a bit more air to the tires
    park on ruibber pads
    hook up battery tender
    On the road by Halloween
    I put mine on jack stands if longer than a couple of months saves the tires and probably good for suspension as well.
  1. CSR season opener !
    By John Z Goriup in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 04-07-2014, 08:11 PM
  2. Off-season storage for my 911
    By Frank911 in forum General Info
    Last Post: 12-17-2013, 11:43 AM
  3. CSRG Season Opener
    Last Post: 04-04-2012, 08:42 AM
  4. Metro NY Pre-Season Extravaganza
    By denson in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 04-17-2010, 07:43 AM
  5. Season Change...
    By Jens in forum General Info
    Last Post: 11-15-2004, 03:28 AM
