Results 1 to 10 of 10
Thread: Sealing instructions service bulletins 911 Coupe and Targa
    The instructions concerning the Coupe is a set of three bulletins about eliminating water leaks. The first one is 13/65, it identifies several points on the cover page, then addresses each of them in the next three pages, with pictures, showing areas affected, giving points of entry and the remedy. The fifth page is recommendations on where to get the materials needed. The next is 18/65, it addresses a few more points in the same manner. They did not get around to “under the hood crest”. I’m digressing again. The third and final one in the set is 21/65, it basically says that drilling a couple of holes in the floor pan as described in 18/65 is such a good idea that it should be done to all cars when they come in for any kind of service. $100
    The next bulletin for sale is 5/68, “emergency action to prevent water entry, wind roar and rustling noises on the “targa”.
    It says that you can replace the top with a newer, lighter one, gives part numbers for both, says that you can put a fixed, I assume glass, window into cars from certain chassis numbers, it gives the numbers, to give you an idea of how much foresight I have I did that a number of years ago to a 68 and threw away the soft window and all the parts. Anyhow, this gives about two and a half pages of instructions to quiet/seal the car, gives part numbers where needed, and has a final page with photographs of figures referenced in the instructions. $75
    This next one is 10/67, it details how to replace the zipper in the rear window of a Targa. This is three pages, the cover, a page of instructions, and a page with photographs of figures referenced in the instructions. $75
    Targa pictures.
    Senior Member Baron's Avatar
    Jan 2007
    Communist Maryland
    email sent
    e-mail replied to.
    One Coupe gone, one left.
    That is real history. Way cool
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Yearly bump, I forgot I still had these.
    PM replied to.
    If you still have the two Targa ones, I will take them.
    Mike (949.338.4591)
    Mike Baum #505
    57 Alfa Romeo Giulietta Sprint
    60 Citroën ID
    61 Lancia Appia Vignale Convertibile
    64 Alfa Romeo Giulia TI
    66 Lancia Flavia Sport Zagato
    69 911S Targa (Soft Window)
    72 Alfa Romeo Junior Zagato 1600
    I've got them. I can call you or my e-mail is cs8815 at aol dot com.
  1. Replies: 0
    Last Post: 02-07-2013, 03:06 PM
  2. WTB: "Service Information: Model 19XX" Bulletins for 1970 thru 1973.
    By derwhite in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
  3. Replies: 6
    Last Post: 06-16-2009, 01:14 PM
