Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Last 1966 911 with Solex carbs
    Carburetor geeks,
    Let's see if we can really determine the last chassis number with Solex carbs. We know (from our "source in the Alps") that 903910 was the last engine with Solex as that was the last type 901/01, series engine. After that, factory went to 907xxx engine series, type 901/05, with Webers and the first was engine 907001. And I have these cars in my data base:
    Chassis Engine
    303585 903804
    303??? 903910
    303810 907114
    303868 907031
    303872 907112
    I'm fairly confident that these all have there original engines but not 100%. Also we know the change took place in Feb. 1966. Help us fill in the blanks. Thanks.
    -Allen-
    I'll send a PM to Pelican Gregk1, he owns or owned 303734, very close to the break. Actually, I think he sold it to Dave Austin AKA MackSkibum.
    I don't understand why you put "xxx," the first Weber engine was 907001.
    Quote Originally Posted by Dr 911E View Post
    Carburetor geeks,
    Let's see if we can really determine the last chassis number with Solex carbs. We know (from our "source in the Alps) that 903910 was the last engine with Solex as that was the last 903xxx, type 901/01, series engine. After that, factory went to 907xxx engine, type 901/05, with Webers. And I have these cars in my data base:
    Chassis Engine
    303585 903804
    303??? 903910
    303810 907104
    303868 907031
    303872 907112
    -Allen-
    Interesting.
    903910- 903804 = 106
    In other words 106 more Solex for VIN's.
    303585 + 106 = 303691
    First Weber car you have is 303810 (engine 907104).
    What kind of carbs did (roughly) 303700-303800 get?
    Look forward to your John's reply w/ info from gregK.
    Richard
    What I had put was confusing and I have edited that post. Also, I correct 907114 (from 907104 which was a misreading of the engine number by me from my pic file.) Thanks.
    -Allen-
    Oct 2008
    Burford, ON, Canada
    I have these in the relevant area:
    303563 903696
    303621 903812
    303779 903800
    303780 903892
    303810 907114
    303838 907246
    Now since the engine numbers started 100 higher than the VIN's we might expect 303810 to have the last Solex engine. However it has either 104 or 114 higher than might be expected. Two things come into play: first is that the engine #'s were not used sequentially (nor were the VIN's for that matter), and second there were probably some losses or holdbacks on the Solex engines, so the Weber's got introduced a bit early. I'd guess the VIN we are looking for is about 303800. But I bet that there are some exceptions to the cut-off VIN.
    Oct 2008
    Burford, ON, Canada
    It would also be useful to try and find the engine build # for the transition. It appears they were building the 901/20 race engines towards the end of the Solex version 901/01 production run.
    304178 came factory with Solexes
    I owned 304178 and it came from the factory with Solexes. Porsche...
    Quote Originally Posted by res0ca5d View Post
    Interesting! Your nice Sand Beige car. Do you have the engine number? In another thread Jose Hinarejos reports 305675 with engine 909445, type 901/5 (as the engine type should be) has Solex! Thanks.
    -Allen-
    Oct 2008
    Burford, ON, Canada
    I show 304178 having engine 907377.
    Who owns this car now? Contact info to be able to get the build #?
    Dave,
    You can reach them here I believe. Thanks. It is starting to look like, maybe?, Porsche put some Solex on 907XXX engines!
    http://www.caporsche.net/
    -Allen-
  1. FS: @Pelican - Solex Carbs for 1965 - 1966
    By StephenAcworth in forum For Sale: 911 Parts
    Last Post: 04-28-2013, 03:37 PM
  2. Solex Carbs
    Last Post: 01-29-2010, 10:29 AM
  3. Solex carbs
    By dallaseurocars in forum For Sale: 911 Parts
    Last Post: 01-28-2010, 02:27 PM
  4. Solex carbs
    By mikez in forum For Sale: 911 Parts
    Last Post: 03-24-2009, 03:14 PM
  5. 65 Solex carbs
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 11-26-2007, 09:28 AM
