Thread: TTG foglight and under bumper fogllight wiring
    I'm installing TN4 TTG foglights and the under the bumper foglights on a 1969 911 and wondering if they can be wired together or does each need to be on it's own circuit with it's own switch?
    As you may know, when both driving and fog lights were installed, they had separate switches. Fog by the cigar lighter and the TTG beneath the speedometer with a miniature bosch switch. If you don't have the miniature switch or you don't want to install a second switch, you could put the driving lights on the hi beam circuit with a relay and the fogs independent with its own switch. I would not want to be in line of those hi-beams
    Olin
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Jul 2003
    Santa Cruz, CA
    Olin, sounds like he is using two pair of fogs. One TTG and one under bumper.
    You could run both of them off one main circuit/switch. I'd use the switch to activate the relay coil only and have the light current through the relay contacts. I would recommend beefing up the supply wiring to the relay, and the output of the relay to the fuse panel and then parallel to your two sets of lights through two separately fused circuits. The fused output circuits to your two pairs of lights could then remain standard wiring.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  1. WTB: Foglight covers for front bumper
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 01-18-2014, 02:53 PM
  2. FS: NOS foglight covers
    Last Post: 07-05-2012, 04:36 AM
  3. WTB: Foglight switch 69-73
    By EA911 in forum For Sale: 911 Parts
    Last Post: 04-06-2009, 10:16 AM
  4. I need help from the foglight gods
    By tomkirkcis in forum Technical Info
    Last Post: 12-27-2008, 02:26 PM
  5. fs: swb foglight brackets
    By garyz in forum For Sale: 911 Parts
    Last Post: 08-18-2008, 02:11 PM
