Results 1 to 10 of 19
Thread: WTB '67 911S Below Door Aluminum/Rubber Trim Pieces
    Jan 2004
    Fullerton, CA
    I need the long rubber inserts that mount under the aluminum trim pieces - these mount to the car under the pass and driver door areas. My aluminum pieces are useable but would prefer a nice set of aluminum and rubber. These are the narrow ones - about 1" in width. I can't find repro sets anywhere.
    Thanks.
    May 2006
    CT
    I've got this pair.
    PM me for pricing
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Jan 2004
    Fullerton, CA
    Sorry, senior moment. I don't need the gaskets between the aluminum piece and the car. I need the rubber insert that slides into the aluminum piece after it is attached to the body w/screws.
    Stoddard
    901-559-101-22
    Insert for original narrow deco strip, 2 req'd.
    Fits 1965-1973.
    $25.41
    My favorite go-to guy is Paul Domitrovic: pdomitrovic@stoddard.com
    440-951-1040
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    Jan 2004
    Fullerton, CA
    Stoddard doesn't have the wide S rubber inserts, only narrow non-S.
    Any leads on either good condition used or perhaps repros?
    Thanks for any help/leads.
    Hi,
    As far as I know no one makes a repro 67 S (wide) sill trim insert. I was fortunate to find a NOS pair here in the UK. I could ask to see if they had any more but they were not cheap .If originality is not 100% important you could trim down some insert that is used on the full length S trim, used from 68-73.
    Alan
    Jan 2004
    Fullerton, CA
    Hi Alan - pm sent.
    thx.
    Jim
    Beck's Independent in Phoenix can source repro rubbers or tell you where to get them.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    Jan 2004
    Fullerton, CA
    Alan - would you be able to assist in obtaining these? I've tried Beck's but they aren't responding.
    thx.
    Jim
    Aug 2007
    Phila Pa. area
    Question
    The narrow alunimum trim strips and rubber inserts for under the door are reproed, and there are plenty of used rubber inserts around, as well as used alunimum strips.I think the alunimum strips also require a rubber strip betweem the metal and the body ( cannot remember). Is it that everyone is out of the repro stuff, or are you looking for something else?
    Mike
  1. Aluminum door sill trim OEM
    By Bobboloo in forum For Sale: 911 Parts
    Last Post: 12-31-2008, 06:48 PM
  2. RS Door Panel Chrome Trim Pieces???
    By bob tilton in forum General Info
    Last Post: 08-20-2007, 09:30 PM
  3. Aluminum dash trim pieces
    By e72phil in forum General Info
    Last Post: 07-19-2007, 12:07 PM
  4. WTB: Interior door aluminum trim and plastic
    By MarkS in forum For Sale: 911 Parts
    Last Post: 04-07-2007, 02:12 PM
  5. Correct trim, rubber for 70 911 door/window
    By rich roush in forum Technical Info
    Last Post: 02-24-2006, 07:54 AM
