Thread: Speedo cable connection to Transaxle
    I have a '66. I believe the transaxle blade that connects to the speedo cable is bad. It appears the blade has broken off. Is this the type of repair best left to the pro's? Suggestions...
    Thank you.
    No, you can replace the bad unit by removing the set screw on the trans and pulling it out. Then unscrew the right angle bad part and screw on the new one. Then reinstall with new o ring.
    Senior Member 68911USA's Avatar
    Jan 2009
    Salisbury, MD
    I just did this. You need to be able to hold the engine/transmission up with a good jackstand so you can move the transmission mount out of the way, too. Otherwise, not a hard job, just like Fritter said. Mine needed some "persuasion" to come out of the transmission, but was fine. Reinstallation was a breeze, car was back on the ground in no time. Good luck!
    1968 Porsche 911 #11830133 (2009- 2012)
    1968 Porsche 911T #11820522 (1997-2007)
    Registry Member #1536
    Hagerty Insurance Guy
    Missing my Porsche. Need to find another SWB project!
    Current cars:
    1918 Willys-Overland Model 90BT
    1966 Sunbeam Tiger Mk1a
    1977 Chevrolet Suburban C20 "Trailering Special"
    1983 Ferrari 308 GTS Quattrovalvole
    1992 RHD Toyota Century
  1. FS: Early 911 dual battery positive connection cable
    By MountainRoads in forum For Sale: 911 Parts
    Last Post: 03-11-2013, 06:29 AM
  2. FS: Speedo Cable - BRAND NEW
    Last Post: 06-17-2011, 10:48 PM
  3. Speedo cable
    By drwhosc in forum Technical Info
    Last Post: 05-01-2008, 05:10 PM
  4. speedo/ odo cable removal
    By fuegos100 in forum Technical Info
    Last Post: 06-01-2004, 06:50 PM
  5. Need to be talked through replacing a speedo cable please!
    By wolfturbo in forum Technical Info
    Last Post: 05-08-2004, 08:30 PM
