Results 1 to 2 of 2
Thread: Gas Tanks
    Gas Tanks
    Hello all....
    I'm having trouble finding a tank for my 69 T....It seems EVERY place is on back order for the galvanized reproductions...I've tried the unusual suspects Performance Parts, Pelican, etc but no dice ....Does anyone have any suggestions?
    thanks!
    B.Sloan
    Sep 2006
    Eagle, Idaho
    If you are into authenticity and want a good OEM gastank, first place I would go would be some of the West Coast Porsche dismantler. Here are 2 of the best:
    EASY Tel: 510. 653. 3279 www.easypor.com
    or
    Paretsheaven Tel: 1. 800 767. 7250 info@partsheaven.com
    If faithful period restoration is not that big a factor, I suggest considering a later model Carrera tank. It fits perfectly, has larger fuel capacity ( 20 + gallons) for longer range between fiil-ups, but requires a space saver spare tire. Those tanks too are available from the above source as well. To offset the increased weight in the front of the additional fuel load, a 944 turbo forged alum spare ( as shown in the attached shot of my trunK) will save you about 18 lbs.
    Before installation and invetsing a lot of time painting and restoring, may I also recommend that you take it to your local Gas Tank RENU-USA franchiser for a pressure / leak check and sealing. They do good work at a reasonable price......and as Master card claims, peace of mind: priceless.
    I think either way is preferable to buying a new repro product.
    JZG
  1. Oil tanks
    By Braukuche in forum For Sale: 911 Parts
    Last Post: 10-13-2012, 07:59 AM
  2. Refinishing Oil Tanks
    By rcnagel in forum Technical Info
    Last Post: 08-29-2012, 02:21 PM
  3. RS plastic tanks
    By dave29 in forum For Sale: 911 Parts
    Last Post: 05-17-2012, 10:23 AM
  4. New 85 L Plastic gas tanks
    By gulf908 in forum General Info
    Last Post: 01-17-2012, 09:10 PM
