Results 1 to 8 of 8
Thread: 73 RSR Pedal Box
    Senior Member mrg3.6's Avatar
    Nov 2007
    United Kingdom
    73 RSR Pedal Box
    Does anyone have some close up photographs of a 73 RSR twin mc pedal box both in-situ and out of the car, some close up's of the twin ATE fluid reservoirs would also be appreciated.
    Thx
    Martin
    Martin, this is the pedal box, an accurate repro version from Mittelmotor, which includes the chassis piece, in white, which needs welding in. Only 1000 Euro's.
    And these are the ate fluid reservoirs, small one from the 356 which you can still pick up but you have to fabricate the brackets now, and as for the big one, good luck!
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
    Nov 2007
    United Kingdom
    Quote Originally Posted by Mike_Moore View Post
    Martin, this is the pedal box, an accurate repro version from Mittelmotor, which includes the chassis piece, in white, which needs welding in....nd these are the ate fluid reservoirs, small one from the 356 which you can still pick up but you have to fabricate the brackets now, and as for the big one, good luck!
    Thanks for that Mike.
    So it would seem that the original RSR twin bias MC's projected through the bulkhead rather than the more common place twin MC 'replica's which run the two cylinders vertically within the confines of the footwell.
    Martin
    Exactly Martin, which is why most people convert their existing box to twin cylinder inside the footwell, saving chopping about the chassis.
    Mike
    cheers, Mike
    Member#1664
    Nov 2007
    United Kingdom
    Mike (or anyone) do you know what diameter (AP?) master cylinders were used for the front and back brakes respectively?
    Thx
    Martin
    Jan 2003
    UK
    Martin - they used a 22mm & a 17mm master cylinder.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Nov 2007
    United Kingdom
    Quote Originally Posted by andyjboy View Post
    Thanks Andy - have you ever driven an RSR/SCR with a twin MC setup, if so what were your impressions on the amount of pedal effort vs pedal movement required to stop the car and would you be comfortable using such a setup (with Turbo calipers) on the road?
    Martin
    Jan 2003
    UK
    Martin - I have driven an original 2.8RSR but it was ~ 15 years ago & I have no idea what the pedal box/master cylinder set-up was ... mostly all I remember about the car was that it was a real pig to drive on the road (on its ancient rock hard 'slicks') !!
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. Clutch pedal interacting with brake pedal
    By POS in forum Technical Info
    Last Post: 11-30-2012, 03:05 PM
  2. pedal bushings
    By Christopher p Steimer in forum Technical Info
    Last Post: 09-11-2012, 08:25 AM
  3. FS: Gas Pedal
    Last Post: 05-13-2012, 07:37 AM
  4. FS: SWB Pedal Box
    By jhora in forum For Sale: 911 Parts
    Last Post: 09-13-2007, 12:27 PM
  5. WTB: 69S gas pedal
    By dhopkins in forum For Sale: 911 Parts
    Last Post: 07-14-2005, 12:07 PM
