Results 1 to 7 of 7
Thread: 71 dashboard speaker grill repair help needed
    The speaker grill in the dashboard has four embedded screws that screw into plastic holders that fit into the frame of the dashboard. All four of the plastic holders have dried out and broken on my 71.
    Anybody figured out a repair for this? couldn't find anything with search
    __________
    Sean
    1971T restoration in progress http://911restorationmadness.blogspot.com/
    1982 PCA club racing #372 D-Stock
    Registry #1595
    Im also needing 4 of the plastic holders. Any help is appreciated
    1997 993 C4S, Not totally stock
    2015 GTI
    1991 E30 M3
    1970 911T, Lilly. Slate Gray 3.2ss PMO etc Sold!
    http://forums.pelicanparts.com/porsc...ect-lilly.html
    Early S Register Member #1386
    Believe, it or not, I have used wall plug anchors. Mine are blue and they go into sheetrock to hold a screw. Sounds silly, but it works. Just make sure to get the right size. Take the speaker grill to the hardware store to fit it properly. The length is not that important as you can trim it to fit.
    RGruppe member 445
    That is brilliant!!! Thanks!
    2015 GTI
    1991 E30 M3
    agreed 100% on the plug wall ancors, I installed my speaker grill the same way over 5 years ago using the drywall screw anchors from Home Depot the blue ones.!! Still strong and holding!!
    JW
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    S Registry Dues Paying member #1438
    great idea...thanks
    __________
    Sean
    Registry #1595
    Glad that helped.
    RGruppe member 445
  1. FS: 73 dash with speaker grill + 69 speaker grill minty
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 02-06-2013, 06:21 PM
  2. Dash Speaker Grill Dimensions Needed
    By ibmiked in forum General Info
    Last Post: 02-09-2010, 05:37 PM
  3. Early 911 Dashboard and Speaker
    By tgittens in forum For Sale: 911 Parts
    Last Post: 10-05-2009, 08:17 AM
  4. Early Dashboard Vinyl W/speaker Holes Available
    By carsngolf in forum General Info
    Last Post: 03-11-2008, 10:51 AM
