Thread: 69-71 Ignition Locks
    Jul 2003
    Santa Cruz, CA
    Question 69-71 Ignition Locks
    I know the door handle lock tumblers can be re-worked to match a key but, can the ignition lock be reworked in the same manner? Hoaw about the glove box lock?
    The key to my 70 was a generic replacement and is so worn that there is no way I can have a new key cut. I've a line on both original keys from another 70 with at least one tumbler that I'd like to use provided I can use my existing ignition switch lock.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    re key 70 lock
    just finished having a new key made for a 70 914-6 set up. the cylinder needs to go to a very good lock smith, some one with a lot of experence. the cylinder has to be unpeaned to get to the disks, replacement locks form what was told to me are no longer available with the crome center only black
    Michael,
    Let me know if you need any of the flat wafers, as I have an assortment of these that you might need.
    The following web links may be of interest to you:
    http://www.pelicanparts.com/techarti...lock_rekey.htm
    http://www.ebbo.org/re_keying.php
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Jul 2003
    Santa Cruz, CA
    Good stuff guys, thanks!
    Since I'm a stickler for patina originality, I'm gonna pull the trigger on the keys and single lock. I knew I'd have no problems with the door locks. It was the ignition I was worried about.
    I knew I could have new keys cut from my ignition lock code but, then they would be the new replacement keys and I've heard the red Valet key has a different head style from the original.
    Sometimes its the small things....
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Michael
    If your wanting to be down without keys for a bit and all the parts are removed, I can match and re-key the ignition and doors for you. It's not too difficult and since I purchased an old factory re-key kit with thousands of tumbler tabs it's made the chore much easier. I've re-matched quite a few know with great results.
    I dont do it for a living, it's just fun!
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    S Registry Dues Paying member #1438
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by jonnyw View Post
    Michael
    Thanks for the offer! Down without keys is the least on my long list.
    I'm going to do the handles myself for the fun factor, but, I'll take you up on the ignition...
    So, whats the scoop on the glove box lock with the Valet key? Same as with the handles? I've never had both types of keys in my hands before so I don't yet know the difference.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  1. FS: Wheel Locks
    Last Post: 12-18-2011, 08:29 AM
  2. Center Locks
    By Edwin Ek in forum Off Topic
    Last Post: 02-05-2010, 08:44 AM
  3. Wheel locks 911
    By platas in forum General Info
    Last Post: 11-15-2006, 12:48 PM
