Results 1 to 9 of 9
Thread: '67S brakes
    '67S brakes
    Other than the caliper and rotor, are there any other part differences between the standard and "S" set-up for 1967?
    I heard long ago, that the hub might be a different dimension?
    Todd Rudaitis
    Orange, CA
    Hubs (frt) and dog bones (rear).
    That's all I believe.
    Richard
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Yup. What Richard said.
    Front Hubs; as they basically split the difference of the new 7mm spacer in the caliper 1/2. There was about 3.5 - 4mm shaved off the backside of the hub.
    While the dog bones are nice to have, the same can be accomplished with a few well placed washers (never bothered Tony on the Ferrari line).
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Oct 2008
    Burford, ON, Canada
    What is a "dog bone?"
    Eric, the brakes came back fabulous. I will post a separate picture thread as a thank-you.
    Thanks for the replies guys...
    I should be covered on the hubs.
    Another question: Since the thicker hub was used from '67 on up on vented cars, I'm assuming that part #8 on the diagram is used based on the spindle, not the hub/bearing combo. Make sense?
    Todd
    p.s. Eric, still rounding up the parts to send your way!
    dog bone
    John and others
    The dog bone is a washer shaped as a dog bone or weight dumble.
    If fellow S members are in search of these, I had a few exact copies made, but stainless instead of iron. They cost me roughly $5 each.
    Richard
    Dec 2002
    Sandy, Utah
    Quote Originally Posted by tar356 View Post
    Hard to say what part #8 is without looking at the PET myself but... there's a spindle base that fits tightly in the seal. It may be that and yes, that would have no relevance to the hub/bearing combo. Those are installed and removed with heat.
    It looks like that may be the base but, if we're going in order, #9 should be the base and then the seal then the inner bearing and race, then the hub, then outer bearing and race etc.
    John, with fronts they moved the wider section of the vented rotor "out" so the hub was shaved a tad to do this. With the rears it moved in so... dog bones moved the caliper in 4 - 5mm(?) (Richard would know for sure) to accomodate for this. Glad the calipers arrived OK.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    I'm thinking is serves two purposes:
    1. To provide a surface for the seal run against.
    2. A surface for the inner bearing to seat against.
    I have to assume there is some sort of difference in the two strut units/spindle lengths that requires a different spacer to keep the hub assembly located in the correct plane?
    I'll mock up a "vented" hub on the '67 strut and check for clearance, etc.
    I'm probably splitting hairs right about now!
    Todd
  1. Replies: 43
    Last Post: 01-16-2014, 03:10 PM
  2. Replies: 11
    Last Post: 12-10-2012, 02:58 PM
  3. Brakes, which way to go
    By Max (SD) in forum Technical Info
    Last Post: 07-14-2011, 10:21 AM
  4. Who wants some SWB big brakes?
    By mjmoran in forum Technical Info
    Last Post: 12-22-2009, 12:01 PM
  5. Brakes For '67 911
    By jaudette3 in forum Technical Info
    Last Post: 08-11-2006, 07:33 PM
