Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: oil tank to cooler hose
    Apr 2004
    I replaced mine (on a '67) with Stoddard part #901-107-301-12 (#4 in upper left pic) and it seems to hang very low, to a point where it is about 6 inches off the ground.
    Seems like it is too long.
    Anyone else use that replacement part and notice that ?
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    May 2006
    CT
    I have this OEM hose in good condition.
    PM me if interested
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Apr 2004
    Could you measure that one and tell me the dimensions ?
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    Mar 2006
    Louisville KY
    John,
    There are two lines 901.107.301.13 and the one you got 901.107.301.12. that might be the problem your having. I think you got the oil line for a 69> LWB car. The interesting part is that the parts diagram know only shows one line.
    A little more digging on my end shows the SWB line is NLA and has been replaced withe LWB line.
    Tony
    Tony Proasi
    52 split window coupe
    Apr 2004
    I have both the .12 and .13
    Man I hate &#@*%$ Stoddard - are there ANY parts they claim will work for '65 -'68 cars that actually fit !!!!! ??????
    So what do you good people use ? Any one else change that line ?
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    Apr 2004
    No one else with a '65 - '68 car has had to change their 40 year old lines ???
    Tom:
    That's what I was looking for but would prefer a fresh line.
    Is it possible to replace the hose on that part ?
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    Arrow oil tank to cooler hose
    You should be able to unscrew the hose ends and replace the hose with
    whatever length you want. I've done it before on a 916 I used to own.
    Dave
    May 2006
    CT
    I'll measure it and check the hose.
    I mah have a couple of these.
    I'll get back to you.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Hi John,
    I can make you the correct line using your original fittings. I have the correct Cohline hose and tools to rebuild your oil line.
    This thread has some good info, http://www.early911sregistry.org/for...ad.php?t=26299
    Please let me know if I can help.
    Best regards,
    Brad
    Apr 2004
    Quote Originally Posted by tom1394racing View Post
    Tom:
    Thanks, that would be great - I would be interested in picking up one from you.
    The one I am replacing is a replacement that started weeping.
    I'll send you a pm.
    And if necessary (if it is doable) I could have Brad replace the hose.
    Thanks you guys.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
  1. Oil Hose-Case to Oil Tank Install
    By gsjohnson in forum Technical Info
    Last Post: 07-19-2013, 11:28 AM
  2. Oil hose from case to oil tank?
    Last Post: 02-10-2013, 05:53 PM
  3. LWB Oil Tank by Pacific Oil Cooler
    By 304065 in forum For Sale: 911 Parts
    Last Post: 03-22-2011, 01:28 PM
  4. FS-NOS 65-71 engine to oil tank hose 911
    Last Post: 03-13-2011, 11:24 PM
  5. Oil tank/cooler fittings question
    By gtgroupe3 in forum Technical Info
    Last Post: 07-24-2008, 09:24 PM
