Thread: inertia reel seat belt won't reel in
    My ORIGINAL passenger side seat belt in my '72 Targa seems broke
    The belt was accidently pulled out completey, and now it won't reel in
    Other than taking the interior panels off to gain access, anyone have any ideas? Once I do get to the reel, repair or replace?
    [SIGPIC][/SIGPIC]
    Ray Crawford
    Early S Registry #271
    R Gruppe #255
    '70 911 S Coupe 2.9 w/MFI Twin Plug "Flairs n Chairs"
    '72 911 S Targa 2.4 w/MFI
    PEP. Professionally Engineered Products.
    http://www.peparts.com/StoreFront.bok
    Good luck,
    Tom
    PS: I once had a reel that wouldn't retract but I figured it out. A tree had caused it to lock in position (around me). Go figure
    Early S Registry #235
    rgruppe #111
    Senior Member 68911USA's Avatar
    Jan 2009
    Salisbury, MD
    If you hold the belt where you can be sure it's pulling straight out of the retractor, giving a firm "pull" to it but not snatching it, will that get it to retract? I had this happen once on a different old car ('69 Benz) with Repa retractors, and this would happen from time to time. I could pull on it firmly, making sure there was no angle to the pull to the retractor, and then slowly feed it back in as it began to retract, keeping light tension on the belt. Also, if the retractor has moved from vertical inside the panel, it can make it impossible to reel in just due to how the mechanism works. Perhaps when it got pulled all the way out, it also moved the reel a bit inside the panel? Just an idea.
    1968 Porsche 911 #11830133 (2009- 2012)
    1968 Porsche 911T #11820522 (1997-2007)
    Registry Member #1536
    Hagerty Insurance Guy
    Missing my Porsche. Need to find another SWB project!
    Current cars:
    1918 Willys-Overland Model 90BT
    1966 Sunbeam Tiger Mk1a
    1977 Chevrolet Suburban C20 "Trailering Special"
    1983 Ferrari 308 GTS Quattrovalvole
    1992 RHD Toyota Century
    Great advise from 68911USA...I have had them do the same and sometimes just the angle jams it...
    Sometimes the inertia wheel locks and it needs to just move a little to release..if the spring is broken then you will have to remove it...I have replaced the spring before but it is a challenge....compact thing and it will "kill" you if it gets unwound....
    Good luck!!
  1. Updating to inertia reel seat belts in a 67 S?
    By TheBen in forum Technical Info
    Last Post: 10-24-2013, 09:09 PM
  2. FS: PEP Inertia Reel 3-Pont Seat Belts
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 03-13-2013, 04:04 PM
  3. Inertia reel seat belts
    By cwb in forum Australia
    Last Post: 04-11-2012, 07:03 PM
  4. Fs: 73 Inertia Reel Seat Belts, Sport Seat Brackets
    By rick2 in forum For Sale: 911 Parts
    Last Post: 01-07-2011, 10:29 PM
  5. Correct seat belt reel covers for '70?
    By teenchy in forum Technical Info
    Last Post: 11-15-2009, 01:44 PM
