Thread: Where to get a new cable housing for the hood release cable?
    I recently got a new hood release cable, but the replacement cable is only the thin wire without the exterior cable housing which I also need to replace.
    I've been told that I should try a bicycle shop for a cable housing. PET doesn't show the part number so I have no idea where else to look. I really don't want a used one. Any other ideas? Will the bike shop cable housing work?
    Dave
    What you are looking for is like PVC I think but you can buy the sheath material from places like:
    http://www.flanderscables.com/
    I make my own for bikes. Lots of fun.
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    Dec 2008
    Woodland Hills, CA
    These guys should have it as well.
    http://www.speedometershop.com
    That's all there is, there is no outside housing, the cable goes through the metal tube that is welded to the body.
    Ah, I see. Unfortunately, my car is an '86 which doesn't have a metal tube. It uses a cable that is sheathed along its entire length. I've turned it into a longhood, so the original cable isn't long enough and the original cable housing is in bad shape.
    I appreciate the suggestions.
    Dave
  1. tank release cable clamp
    By moito in forum Technical Info
    Last Post: 09-22-2017, 04:35 PM
  2. Help me fish out my 73.5T's hood latch cable
    By bford in forum Technical Info
    Last Post: 12-27-2013, 08:42 PM
  3. Front Hood Latch Cable question
    By 21window in forum Technical Info
    Last Post: 10-08-2013, 03:28 PM
  4. WTB Front hood latch top and bottom with cable if possible
    By Gringo in forum For Sale: 911 Parts
    Last Post: 10-13-2008, 11:08 AM
  5. Front hood latch backup cable?
    By pwd72s in forum Technical Info
    Last Post: 12-16-2002, 11:54 AM
