Thread: 1965-1969 Clutch Bolts part number?
    Nov 2002
    Fremont, CA
    Hello,
    I have looked everywhere but haven't been able to find the part number for the six bolts on the pressure plate for a 2.0L car.
    Thank you in advance,
    Scott
    scott kinder
    kindersport@gmail.com
    Registry #614
    900 075 104 01 M8 x 15 quantity 6, don't forget the B8 lock washers under the heads
    Nov 2002
    Fremont, CA
    Are the lock washers a spring type washer?
    Thank you for the part number!
    scott kinder
    Registry #614
  1. Replies: 4
    Last Post: 08-25-2013, 10:08 AM
  2. 69S F&S Clutch Part Numbers
    By greens in forum Technical Info
    Last Post: 03-07-2009, 05:07 PM
  3. Are clutch pressure plate bolts reusable?
    By caproader in forum Technical Info
    Last Post: 11-21-2008, 06:29 PM
  4. help ID this part number
    By typ901 in forum Technical Info
    Last Post: 01-18-2007, 12:40 PM
  5. Correct color of bolts for a 1965
    By Bobs 67S in forum Technical Info
    Last Post: 04-05-2005, 07:45 AM
