Thread: Hand Throttle Question
    Good afternoon. Question regarding the hand throttle on my 70 T. For some reason when I lift it, it functions, but there is a spring in place, or something else, but feels like something is pulling it back down. Any idea on what might be causing this? I thought it might be getting hung up in the ebrake boot but that is not the case.
    Gary
    Gary Smith
    1970 911T
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    Gary-
    The return spring of the throttle linkage is pulling it back down. The lever maintains its position by friction. If you pull up the emergency brake boot, you will see a nut at the hand throttle lever pivot. If you tighten this nut a little, it will add friction that will enable the lever to maintain its position.
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Sounds easy enough. Thanks Scott!
    Gary Smith
    1970 911T
  1. MFI hand throttle adjustment
    By bliebler in forum Technical Info
    Last Post: 10-23-2011, 03:56 PM
  2. Hand Throttle help.
    By 1971-911T-Mark in forum Technical Info
    Last Post: 03-30-2010, 10:56 PM
  3. Hand Throttle Decal?
    By fryardds in forum General Info
    Last Post: 02-25-2009, 04:44 PM
  4. Should my car have a hand throttle?
    By Davz912/911 in forum Technical Info
    Last Post: 03-19-2007, 02:00 PM
