Thread: Center tunnel brake hardline replacement
    Isn't chemistry always nano?
    Aug 2006
    As I failed inspection due to a weeping front caliper, the old girl is up on jackstands and getting the full suspension redo - polybronze, ect along with Eric Shea's kicken brembo upgrade for the early 3" spacing. Well given that the hardlines have been there for 42 years, I figure its time for replacement. I'm told that the center tunnel line can only be redone when the motor/tranny is out. Can one just snake a long piece of braided hose down the tunnel? I'm not changing motors for at least another year yet and the exposed hard lines do have visiable pitting - enought that they are getting tossed while everthing is appart.
    Thoughts anyone?
    If you use that much braided line you will have a softer pedal.
    i just pulled my center tunnel line yesterday.
    my engine is out.
    taking out the old line was easy;
    2 circlips and grommets at either end.
    there are 2 metal tabs accessible thru the openings in front of the handbrake that must be pried apart, so the carpet has to come out.
    i attached a wire to my old tubing to help fish the replacement.
    i bet with a gentle curve you could pull a hard line back in place
    bob moglia
    '72 E sunroof coupe
    Aug 2006
    Thanks!
    Thanks for the info. Robmog, I'm wondering if I couldnt fish it in from the front. Any idea if there is enought room from the shifter access to get a hand in the tunnel to steer it to the rear mount point?
    the rear exit is easy, you can see it from the rear vent/shift couple access
    the front is a bit trickier with the speedo cable and hard fuel lines.
    with a bright light (outside) the line is stiff enough to position.
    bob moglia
    '72 E sunroof coupe
  1. Source for Center tunnel sheet metal?
    By jpnovak in forum Technical Info
    Last Post: 02-25-2015, 09:18 AM
  2. Rallye Kit center tunnel question
    By jimhuiz in forum General Info
    Last Post: 09-13-2013, 01:53 PM
  3. WTB: SWB rubber mat for Center Tunnel
    By jaldeguer in forum For Sale: 911 Parts
    Last Post: 07-29-2013, 12:26 PM
  4. Replace brake line through center tunnel
    By jesseandersson in forum Technical Info
    Last Post: 11-29-2011, 10:35 AM
  5. WTB: Center tunnel mat for a 1965 912.
    By dhopkins in forum For Sale: 911 Parts
    Last Post: 11-20-2010, 08:33 AM
