Results 1 to 7 of 7
Thread: Oil Temp Gauge Wiring ??
    My Oil Temp guage is pegging at the top of the scale as soon as the Key is switched on. I've checked the wire for continuity and it appears fine. I dealt with the problem by installing a temp VDO guage under the dash, and I want to remove it, so time to figure it out.
    The other side of the guage (Oil pressure) is working fine. To me I'm thinking I have a grounding problem at the guage, but why would that not effect the other side? of the same gauge?
    How about the oil tank level guage to the left, it is also pegging at top of range. I thought that was because I hadn't hooked it up when I put the tank in, but it is hooked up. Would it make a difference in either if I put the ground on the wrong post of the tank level sender??
    Thanks, Bob
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
    still chasing this 7 years later. The temp gauge i added works fine on the sender i have, but i don't have an early sender, i have a later sender.
    Is there a change with how the gauge works with the early 911/356 sender and the later 69 on sender?
    Both are available, but the pre 68 version is about 200 more than the 69-78 version
    65-68 PN 901-741-632-00 superceeded by 901-741-632-01
    68-79 PN 901-641-632-00
    Bob
    Bob Petitt
    2006 Volvo XC90,
    Your temp gauge temperature range must match the temp sender rating. If the gauge is going full scale with the ignition on, then if you pull the wire from the sender and ground it it should full scale the opposite way.
    thanks Ed, so when i drive it the temp drops to bottom of range, i guess i'm buying a 250-$ sender unless somebody wants to send me one on the cheap.
    bp
    Bob Petitt
    2006 Volvo XC90,
    Jan 2006
    Naperville, IL
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Nov 2002
    San Dimas, CA
    You might want to contact North Hollywood Speedometer or Palo Alto Speedometer. I had a similar resistance range problem some time ago and got a sender from North Hollywood Speedometer. I don't recall what it cost, but I guarantee you if it had been anywhere near $ 100 I would remember.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Nov 2002
    San Dimas, CA
    I see you took my advice before I gave it http://www.early911sregistry.org/for...l=1#post881011
    Jim Alton
    Torrance, CA
  1. VDO Outside temp gauge
    By geneulm in forum For Sale: 911 Parts
    Last Post: 06-13-2012, 08:11 AM
  2. VDO outside temp gauge
    By 66S in forum For Sale: 911 Parts
    Last Post: 02-17-2010, 04:34 AM
  3. Outside Air Temp Gauge
    By 67softwindow in forum General Info
    Last Post: 02-05-2009, 09:49 AM
  4. wtb: oil press/temp gauge & 914 gas gauge
    By cosley in forum For Sale: 911 Parts
    Last Post: 12-30-2007, 07:35 AM
  5. WTB: 68 temp gauge
    By preS in forum For Sale: 911 Parts
    Last Post: 12-04-2005, 03:01 AM
