Thread: flapper box stud repair
    when i removed my rotten heater boxes i broke 3/6 studs!
    my fix:
    1: cut off flush
    2: 5 mm drill thru center and m6 tap
    3: cut head off m6x1" bolt
    4: screw in new "stud"
    5: braze base to secure
    good as new and correct
    bob moglia
    '72 E sunroof coupe
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Nice work yet again Bob
    I wonder if PB Blaster would have helped? Looks pretty dry (no oil residue).
    Olin - Member #1375
    1972 911T
    Original
    Options added
    thanks classic.
    i soaked them pretty good with liquid wrench, even tried a torch.
    the nuts were fused and they aren't thick studs that can take a lot of torque.
    when i thought they broke loose the stud was shearing.
    easy fix tho.
    bob moglia
    '72 E sunroof coupe
  1. case stud removal
    Last Post: 03-04-2021, 06:06 AM
  2. Help w/ Wheel Stud Identification
    By 914-6gt in forum Technical Info
    Last Post: 01-09-2014, 07:03 PM
  3. Carburetor Stud Size?
    By Fishcop in forum Technical Info
    Last Post: 12-25-2012, 03:49 PM
  4. Stud Farm
    By Reza in forum General Info
    Last Post: 06-24-2011, 09:34 AM
  5. Loose stud or stripped lug nut
    By denson in forum General Info
    Last Post: 11-10-2008, 04:52 PM
