Thread: Throttle Linkage
    May 2009
    T County, Ohio
    Throttle Linkage
    Here's another!
    I have been preparing to install my rebuilt/cleaned carbs and had one more throttle linkage item. I wanted to put a new boot on this section. So what is the deal with this link? Why the special link? I used the existing link, it seemed ok for now,although this is someones repair. Now that I have the pics, I think I am seeing a fuel line needing attention...oh boy.
    69 911 T #100176 Sportomatic
    Vanagons, 97 Jetta VR6, Misc junk...
    Nick D member #403 nickd's Avatar
    Jul 2005
    Landenberg, PA
    there's a new style of coupler that's worth replacing the old style - I just replaced fuel lines and the coupler gave way during this work - it was the original version - 36 years old so it had had a good run but I'm one lucky guy. If the old style gives way you loose all connection to the throttle - with the new version you at least can get some throttle.....
    your coupler has had some work for sure ....
    Nick D - Run Flat
    1973 RHD 911 Carrera RS #0358 - Fun Car
    2016 Cayenne Diesel - Tow Car
    2017 Macan S - Better Half's Car
    1955 356 Speedster SOLD
    1976 911 2.7 SOLD
    2006 Cayman S SOLD
    2006 Cayenne S SOLD
    2008 Carrera S F77 SOLD
    2011 Cayenne S TOTALLED (T-Boned but kept us safe)
    2015 Macan S SOLD
    2015 GT3 - Track Car
    2016 Cayenne SOLD
    2016 Cayenne GTS TOTALLED (Bloody big deer)
    Still looking for 1st Edition Carrera RS book #358.
    Life is way too short to drive boring cars.
    The "old" factory coupler consisted of two metal washers separated by a rubber piece. The problem was, if the car hit a real bad pothole, the rubber could shear, leaving you stranded.
    The revised factory part consists of the same assembly encapsulated inside a steel barrel that wraps around both ends and encapsulates the washers-- you still get the rubber to dampen engine vibrations from going to the gas pedal, but if the rubber shears the steel barrel holds the washers and you can get the car home.
    Yours looks like somebody brazed the old washers onto a piece of metal in an effort to do the same thing. You can replace it with the new coupler easily.
  1. WTB: 906 Carrera 6 Throttle Linkage
    By 914-6gt in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-23-2013, 09:11 PM
  2. WTB: Weber throttle linkage components
    By 1QuickS in forum For Sale: 911 Parts
    Last Post: 02-22-2013, 04:44 PM
  3. WTB: small throttle linkage pics attached
    By erick72pors in forum For Sale: 911 Parts
    Last Post: 05-19-2011, 12:30 PM
  4. MFI throttle linkage setup
    By Perry911 in forum Technical Info
    Last Post: 02-05-2011, 05:00 PM
  5. MFI throttle linkage question
    By ThomasTe in forum Technical Info
    Last Post: 01-27-2011, 07:29 AM
