Results 1 to 9 of 9
Thread: Hand Brake Switch - light
    Senior Member drwhosc's Avatar
    Dec 2007
    Spartanburg SC
    Does anyone have any pearls of wisdom to adjust the handbreak switch. My light is comming on when the level is all the wy down. Looks like I am getting a ground, adn I am willing to bet there is a way to adjust this thing. When I looked at the mechanism, not clear and easy solutions presented themselves to me.
    thanks -- rr
    71 911E RS Clone (Analog)
    88 928 S4 (V8 Trans Axle)
    99 996 (Daily Beater)
    Early S Registry # 1278
    Pull up the handbrake boot, look on the passenger side of the handbrake lever housing, towards the rear of the car you'll see a single slotted screw, when loosened that will adjust the switch up and down. It grounds against a riveted on copper ground strip up inside the handle.
    Dec 2007
    Spartanburg SC
    your a good man, thanks I will do that tonight
    Apr 2003
    Portland, OR
    I had a similar poblem with my light.
    It turned out it was a defective switch on my master cylinder which I diagnosed by disconnecting the connector from the switch. Once I did that, the light began to operate as expected (hand brake up, light flashes, hand bake down, no light). I replaced the switch on the master cylinder and all is well again.
    Harry
    Member #789
    2009 MB C300
    Harry, that is actually a higher probabilty. We'll see what he finds.
    Apr 2003
    Portland, OR
    Quote Originally Posted by HarryD View Post
    One clarification. I removed the electrical connector from the switch on the Master cylinder, no the handbrake switch.
    Harry
    Member #789
    2009 MB C300
    Apr 2003
    Portland, OR
    Ed, Thanks but you probably have forgotten more than I will ever know on these things.
    Harry
    Member #789
    2009 MB C300
    Dec 2007
    Spartanburg SC
    well i will check that out later today. i found the slotted screw, used a 90 degree flat head and adjusted the height and the light went out. no big drive yet. thanks for the heads up
    Dec 2007
    Spartanburg SC
    Ok time to close this out. Went for the drive yesterday and the light stayed out. By adjusting the slotted screw, I now have 3 clicks before the brake light switch engages. For me, I did not have to go to the master cylinder connection. Again, thanks for the help. I can enjoy myself again and not have to curse a yellow light anymore...
  1. brake light switch
    By jkolesa in forum Technical Info
    Last Post: 04-10-2009, 03:57 PM
  2. Replies: 2
    Last Post: 07-18-2008, 06:11 AM
  3. Hand Brake Light Issue
    By joe912 in forum Technical Info
    Last Post: 10-30-2006, 11:07 PM
  4. Hand brake Blinking Light?
    By jtkkz in forum General Info
    Last Post: 11-12-2004, 12:13 PM
  5. Hand Brake Blinking Light?
    By jtkkz in forum Technical Info
    Last Post: 11-11-2004, 05:39 PM
