Results 1 to 10 of 12
Thread: Ball joints
    Member 1488 MrJTP2001's Avatar
    Nov 2008
    Denver area
    Ball joints
    'While I'm in there' I thought I would replace the bellows on my front ball joints. One of them has a small cut in it so I just ordered enough for all four. Now, I get an email back that they are NLA.
    Are the bellows standard sizes? Can any decent shop supply these parts?
    Any ideas?
    Tony
    68 Sporto Project
    2016 Boxster
    Jan 2003
    UK
    Bellows ??
    If you mean the rubber 'gaiter' & it's split (allowing dirt/grit in) I'd replace the complete ball joint.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Nov 2008
    Denver area
    That's probably what I'll end up doing but I am pretty sure there isn't any dirt in the grease. The ball joints are 41 years old, like the rest of the car, and I had pulled them off during some other work. While on the bench it was stressing the glands to see if they leaked since they were obviously weathered. In doing so I caused a crack about a 1/4 inch long in one of them. I turned the air blue for a couple of minutes, put them in a zip-lock baggie and got on with the project at hand. Only one of the four is cracked but I would really like to find a source so I can replace all of them.
    Tony
    68 Sporto Project
    2016 Boxster
    Quote Originally Posted by MrJTP2001 View Post
    Why wouldn't you just replace them?
    And what do you mean "4"? There's only two ball joints on the car.
    I think you might mean tie rod ends, but there's only two of those, too.
    -Marco
    TLG Auto: Website
    Nov 2008
    Denver area
    The car is 41 years old but only has about 50K miles. The ball joints are tight with no slop at all. They're still quite good. And, my car, a 68 sporto has 4 ball joints in the front. Two tie rod ends and two on the suspension.
    Tony
    68 Sporto Project
    2016 Boxster
    Right. Your 911 has two ball joints and two tie rod ends.
    So which boots do you need?
    -Marco
    TLG Auto: Website
    Nov 2008
    Denver area
    All four of them are badly weathered so I will be replacing all four of them. And, I have found a source for them, total cost about $20. And, my parts book refers to all of them as ball joints.
    Tony
    68 Sporto Project
    2016 Boxster
    Hi Tony,
    Please post the contact info. for this place. I have a new ball joint with a torn boot that I'd like to replace.
    Thanks!
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Nov 2008
    Denver area
    I can't guarentee this place since I haven't recieved anything from them yet. When Pelican told me they were NLA I checked AutoAtlanta.com and they said they had them. They accepted my order and my credit card but I haven't seen the product yet.
    Tony
    68 Sporto Project
    2016 Boxster
    Nov 2008
    Denver area
    Well, it took them a week but now Auto Atlanta says they don't have the bellows either. Replacing the assembly is beginning to look more like the way to go, if they are available.
    Tony
    68 Sporto Project
    2016 Boxster
  1. Are SWB & LWB Ball Joints Interchangeable?
    By mshaver51 in forum Technical Info
    Last Post: 05-27-2012, 10:47 PM
  2. FS: SWB Ball Joints Used
    By jhora in forum For Sale: 911 Parts
    Last Post: 11-16-2010, 06:17 PM
  3. FS: SWB Ball Joints
    Last Post: 05-11-2010, 05:38 PM
  4. F/S Ball Joints
    By Bobby Smith in forum For Sale: 911 Parts
    Last Post: 08-14-2008, 08:47 AM
  5. 65-68 911 912 ball joints new $195
    By WM711 in forum For Sale: 911 Parts
    Last Post: 10-13-2006, 03:08 PM
