Results 1 to 2 of 2
Thread: Oil Tubing
    Aug 2007
    Phila Pa. area
    Oil Tubing
    I got these new oil lines from a Porsche Dealer probably 20 years ago. They ( I have 6 ) did not have a part number on them and I would like to figure out what they fit.
    The threaded fitting has an O/D of 30mm, the length is 41 inches, the length of the upsweep part is 4 1/2 inches, and the O/D of the brass tubing is 22 mm.The bend is about 15 inches from the end, and the one end just stops, no fitting? It does not look like the end was cut off, just Mfg. that way? Any It looks very much like the Trans line from an RSR, except they have a fitting on both ends, and they are one piece from the trans to just before the cooler. Any ideas?
    Mike
    Mike,
    All of the lines that i can find in parts info have fittings on both ends, even race parts. The size of your lines were used in 1972 and up. If you don't think they were cut, maybe a special order line to make a damage repair. The 1972 lower line below the tank has a 90 bend like yours, and the 1974 line below the thermostat also has the same type/size bend. I'll keep looking.
    Ernie W
    member of Early 911S Registry
  1. Gas Tank Vent tubing
    By Dmill in forum Technical Info
    Last Post: 05-10-2022, 05:43 PM
  2. Wiring harness rubber tubing
    By gled49 in forum Technical Info
    Last Post: 03-18-2014, 02:39 PM
  3. Replies: 2
    Last Post: 05-08-2012, 08:40 AM
