Thread: Yargh- oil cooler leak!
    Senior Member 68911USA's Avatar
    Jan 2009
    Salisbury, MD
    It appears I may need to pull the oil cooler on my '68 to see if it is the O rings leaking or the cooler itself. Can I do this with the engine in the car? It's the stock Behr cooler on the engine. Thanks!
    1968 Porsche 911 #11830133 (2009- 2012)
    1968 Porsche 911T #11820522 (1997-2007)
    Registry Member #1536
    Hagerty Insurance Guy
    Missing my Porsche. Need to find another SWB project!
    Current cars:
    1918 Willys-Overland Model 90BT
    1966 Sunbeam Tiger Mk1a
    1977 Chevrolet Suburban C20 "Trailering Special"
    1983 Ferrari 308 GTS Quattrovalvole
    1992 RHD Toyota Century
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    Should be no problem w/o pulling the engine and not that big of problem if you decide to pull the engine too.
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    Mar 2006
    Louisville KY
    If it still has the 68 fan shroud it will have to be removed to gain acess to the top nuts. The later cars had a panel that could be removed to get the cooler off without droping the motor.
    Tony Proasi
    52 split window coupe
  1. Replies: 8
    Last Post: 09-18-2012, 08:28 PM
  2. Oil leak in middle of oil cooler
    By red911 in forum Technical Info
    Last Post: 07-07-2012, 03:11 PM
  3. Replies: 4
    Last Post: 12-07-2011, 09:45 PM
  4. Oil Leak 2.2
    By Type911 in forum Technical Info
    Last Post: 09-18-2006, 07:47 PM
  5. Oil leak on 69S
    Last Post: 01-24-2006, 05:52 AM
