Thread: car starts intermittently
    Hello all - I'm having this issue where every now and then the car won't start when I turn the ignition key. The battery is good, the fuel pump is working - all indication is good and then when I engage the ignition nothing happens. Sometimes I'll still have the key fully turned and all of a sudden it engages.
    Once started there are no issues - car does not cut out which leads me to believe its not the key switch? Any ideas?
    Cheers.
    Bad ignition switch. Confirm by hooking up a jumper on the back of the ignition switch.
    Actually the switch on my '68 went bad a month back...hooked up a jumper and have been starting the car that way ever since....put key in, turn to right, then touch the two wires together that peek out below the dash....look out Sanford and Son.
    Ok - Thank you for your help. I'll source out a switch after confirmation although I do like the "gone in 60 seconds" hot wire theme
  1. This is how it starts...
    By 68911USA in forum General Info
    Last Post: 11-11-2009, 11:43 AM
  2. reminder..LeMans starts at 10:00am CST
    By mike walker in forum General Info
    Last Post: 06-17-2006, 05:48 AM
  3. Odometer Works Intermittently
    By jaudette3 in forum Technical Info
    Last Post: 05-04-2006, 06:58 PM
  4. Targa Tasmania 2005 starts !
    By e72phil in forum General Info
    Last Post: 05-02-2005, 07:08 PM
  5. 72E picks when it starts when icy cold
    By 724d00rE in forum Technical Info
    Last Post: 01-12-2002, 09:38 PM
