Does the `S`tank differ from the `E & T` tanks? I have the console and need everything else...Thanks Cliff.
All the 72 tanks were the same, irregardless of model.
- Ville -
1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
The simplest thing will be for me to look this up in the parts book. I have never seen a 72 tank without the sender hole, but then all the cars I've dealt with all had the oil level gauge. I have seen earlier tanks (68) without the sender hole, but have also seen some without the level gauge and a blanking plate on the hole. Since your car doesn't have the full gauge package that makes it a very unusual 72. Most USA dealers loaded them up. Sorry, I hadn't considered this when I said they were all the same. Most of them had the additional oil fitting for a front cooler, but I have seen a very early VIN car that didn't.
Mine is just an oil tank and sender so I have no idea where it came from, its going for 911R replica.
(and I better check that it actually doesn't have just block-off plate but I'm pretty sure about this)
- Ville -
All '72's should have the same oil tanks (with the caveat of Sportos?). My low option Euro "E" has simple guages and a block off plate on the oil tank.
*extra*
911-207-010-00-"oil tank not for sportomatic"
901-107-636-00-"cover for oil tank"-i.e. oil sender block off plate
911-207-021-00-"oil tank"-i.e. for sportomatic
here is pic of mine, can't say much more about it: (comments very welcome)
- Ville -
I would be worried about corrosion. These things rust out. Out of the 5 I have bought only one was not swiss cheese. Three had previous brazing done. I am taking a 993 stainless tank that I bought and modifying the inlets for my "R" look alike.
67 Normale, Old Rusty
67 R Inspired and on a Diet
73 T/ST Caged Beast
RGruppe #383
S Registry #739
Great comments..My main consideration was to fit a `S ` console to a 911 T tank. Thanks for the info...cliff
