Results 1 to 10 of 11
Thread: never sell a car to friend
    sold one of my cars a year ago to a friend, 88 carrrera. called me the other day car just droped dead when he was driving it so he towed it home .he said it had spark so i figuired no fuel right . so i go over to look at it and give one little shot of either to see if its a fuel problem and the car starts right up and stays running ,so i took it for a 15 min ride and everything seemed ok . i checked the fuse for the fuel pump and it looked ok did'nt see any **** on it .so he takes it out 3 hours later drives it for for a little while and it craps out again ,no fuel . any idea what it could be do these elec fuel pump go out like this or could it be somthing else ???
    Mar 2006
    Louisville KY
    Being an '88 the first thing I would check is the DME Relay under seat.
    Tony Proasi
    52 split window coupe
    Restoration newbie.
    Jun 2007
    San Francisco
    First thing I would do is stop feeling responsible for the car.
    Until the last 10 years most manufacturers only provided a
    12 month warranty from new.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    I remember well contacting the prior owner about a mechanical failure on the first Porsche I owned. He said......"Welcome to the Porsche Club." Good words. Use them.
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    Dec 2004
    Have top agree with Andy. Replace the DME
    This is the voice of experience speaking! Recent experience!
    Was headed from Sacramento to Carmel on Monday morning. I made it about ten miles south of Stockton and the car just "dried up" on me. Spark was good, temp, oil, voltage all good. Just wasn't getting any fuel for some reason. A tow back to Sacramento and a nice call from Frank's (local Porsche shop) and the problem was solved. The wrench at Frank's informed me that the DME is responsible for 90% of all failures on my car ('91 944 S2) and the Carreras like yours. I bought an extra DME and will keep it in my tool kit from here out.
    Start with the DME (about $50) and go from there!
    Go luck!
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    DME problems..
    Im having the same problem in a 78 SC.. All is good, same diagnosis! But no start.. Does this have the same DME?
    does it run hot then die? - rust in the tank?...
    http://forums.pelicanparts.com/showthread.php?t=491587
    __________________________________________
    Paul
    1967 911 coupe polo red (gone)
    1969 911T coupe tangerine(present)
    1973 911T targa arctic white (gone)
    Drive it like you stole it Ghost Chaser's Avatar
    Jul 2008
    dme, fuse box, oxygen sensor
    i had the same problem with my 87 carrera. if you can, borrow someone's dme before you go buying one. try it out. you might find it's not the dme and this will save you some $$$. also check to see if it's the fuse box overheating. this can cause the fuses to loosen up and lose contact. lastly, you might want to consider checking the oxygen sensor (feel free to PM me for an explanation about that).
    i hope everything works out well for you and your friend.
    good luck.
    rich
    Rich
    Early S Registry Member #1394.
    It's nobody's business what cars I own. I will tell you one thing though, they're air cooled and I beat 'em like they owe me money.
    If everything seems under control, you're just not going fast enough. -- Mario Andretti
    May 2006
    CT
    I had this same problem with my brother in law's 86 Carrera. DME relay was the culprit.
    It's an easy DIY quick fix.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Slow In...fast Out RSupdate's Avatar
    Surf City USA
    As a matter of "S.O.P." - if you are an owner of any '84-89 3.2L powered Porsche, you should have at least one spare DME relay....if not two.
    The '78-83 3.0L SC motor is CIS not DME so no relay.
    Johnny Riz
    73E euro 3.2 w. a few goodies
    Rgrp 152
    S Reg 335
  1. 73S hunt for an old friend
    By steve shea in forum General Info
    Last Post: 03-29-2017, 01:29 PM
  2. The passing of a friend
    By RC70SCoupe in forum General Info
    Last Post: 12-09-2013, 04:17 PM
  3. In Search of an Old Friend
    By Tommy911t in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-10-2010, 03:14 PM
  4. My 911S has a new friend.
    By bobmagyar in forum General Info
    Last Post: 12-16-2006, 09:48 AM
