Results 1 to 8 of 8
Thread: rust proofing inner sills
    Sep 2008
    Auckland , New Zealand
    Talking rust proofing inner sills
    as the car is getting new sills due to rust , should i rust proof the inside prior to attaching the new panels I.E may be coat the inside with por15 or sim?
    has anyone done this or recommend this?
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    won't it burn when you weld? I would think that some wax based rust proofing after installation would be good.
    Try cold galvanizing or weld-through zinc primer on the inner surfaces.
    Careful of the fumes when welding. The Zinc is toxic when in a gaseous state and can cause a bad headache and other unpleasant symptoms.
    Wink safety
    Let's face it- Restoring cars can be harmful to your health. I've heard cyanide is a byproduct of welding through zinc. Having said this, Ive welded a lot of galvanized steel and have never had a headache from it but it is not a good idea to breathe any welding fumes. Try to ventilate the area well. I think zinc will protect the steel best after welding. Most paints will burn away at lower temps. That cold galvanize is good for exhaust systems too.
    I have the same philosophy with safety. I just meant to take some simple steps to minimize the hazard. Adequate ventilation should do it.
    I have done a lot of things that are "hazardous to your health"- like driving fast. Living on the edge is more fun.
    I couldnt have said it better
    What is cold galvanizing and how is it done. Seems whatever you do will burn off near the weld. I'm facing the same issue and I was thinking about spraying cosmoline inside after the rocker is installed.
  1. WTB: 70 911 Interior sound proofing panels.
    By mar2mar in forum For Sale: 911 Parts
    Last Post: 10-16-2013, 11:29 PM
  2. Replies: 1
    Last Post: 04-19-2013, 01:37 PM
  3. Rust proofing paint suggestions
    Last Post: 05-06-2012, 04:09 PM
  4. Still looking for a straight, no rust (front pan rust may be ok) tub 69-73
    By berettafan in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 06-08-2010, 05:32 AM
  5. Sound proofing
    By WRGREENER in forum Technical Info
    Last Post: 06-18-2009, 09:02 PM
