Thread: Help with rear bumper-to-body seal
    I've got a fiberglass rear bumper for my RS "interpretation". I'm a little lost on whether I have the right seal for where the top of the license plate panel meets the body, and how it's supposed to be installed.
    Is this the right seal?
    Attachment 68960
    And is this how it mounts to the bumper?
    Attachment 68961
    Attachment 68962
    Any help would be appreciated!
    Dave
    Sep 2006
    Eagle, Idaho
    Yes, you pretty much have it spot on. Since you are using a fiberglass bumper which does not have the rolled bead like that in a steel license plate panel where this seal attaches to, I would suggest a little yellow 3M weatherstripping cement to hold things in place.
    When you mount the bumper, make sure to have some ( 2 I believe) of the rubber "fins" pointing up where the seal presses against the painted steel cross brace between the tail lights, & the 3 lower "fins" should point downwards. The seal needs to rest against the cross brace and there should be no visible gap between the rubber seal and body when looking down at the seal with the engine lid raised. That's important for proper airflow in the rear.
    Good Luck
    JZG
    Thanks John!
    Dave
  1. rear bumper center panel seal
    Last Post: 03-29-2014, 05:42 PM
  2. FS: Narrow body fiberglass rear bumper
    By healeykit in forum For Sale: 911 Parts
    Last Post: 02-13-2014, 07:34 PM
  3. rear center pane to body seal
    By Cliff in forum General Info
    Last Post: 06-27-2011, 05:26 PM
  4. Replies: 1
    Last Post: 11-15-2005, 12:11 PM
  5. Replies: 22
    Last Post: 04-09-2005, 02:12 PM
