Results 1 to 7 of 7
Thread: Suspension pan - repair or replace? ('71 Targa)
    Well, my first setback...found the dreaded 'top down' rust in the suspension pan today. During pre-purchase, I poked around there pretty good with the screwdriver, but that thick undercoating was surprisingly beefy and looked good too. Lesson learned.
    Any rate, here's the deal and the pics...
    - classic top down rust deterioration pattern
    - erosion on driver side corner (see pic); passenger side seems to be absolutely fine (I think the car sat outside tilting to the driver side...water accumulated in front left corner)
    - also erosion in the pan just below the center tank support bolt, about 2" wide (can also see in the pic)
    I've read all the threads on front pan / tank support replacement and understand it's a fairly standard, but involved, procedure for early 911s.
    My question is if there is another repair option aside from the full pan / tank support install? I ask because pass side, tank support, battery tray, etc. are all good...only major concern is the driver side front corner.
    I want to do this 'right' and understand this is more than a cosmetic issue (tbar stability), but at the same time want to know all possible options for repair.
    Thanks again!
    replace. probably won't be the end of the rust you find.
    Relaxed Rich Lambert's Avatar
    Jun 2007
    Lake Stevens, WA
    Replace it. From my experience, the rust you're seeing is a small percentage of the total.
    Rich
    1966 911 #303872
    ES#1197
    RG#478
    Dec 2004
    SE Michigan
    Replace. Definitely.
    Bill G.
    1968 911 Ossi Blue coupe...restoration complete!
    EarlyS #718 | RGruppe #437
    Sep 2008
    Auckland , New Zealand
    Talking
    mine had less rust than this and i have totally replaced it ... why take the chance
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Yep, I pulled out the tank support and, suffice to say, the decision was made for me. New pan it is.
    Restoration Score at the end of week 1: Scope creep 1, Wishful thinking, 0
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    I also had less rust that yours and replaced the entire pan and tank support. Once you remove the tank support you may find more rust. This is usually the case.
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
  1. Can I repair/replace fender bracket mount on battery box?
    By mobius911 in forum Technical Info
    Last Post: 04-14-2012, 08:48 PM
  2. WTB Front suspension to replace collapsed 911E
    By rst73 in forum For Sale: 911 Parts
    Last Post: 07-07-2010, 02:00 AM
  3. Turn Signal Switch Repair or Replace
    By 356robo in forum Technical Info
    Last Post: 04-19-2007, 11:07 AM
  4. FS: Front Suspension Repair Panel
    By rick2 in forum For Sale: 911 Parts
    Last Post: 04-09-2007, 03:08 PM
  5. front suspension pan repair
    By 911kiwi in forum Technical Info
    Last Post: 09-16-2004, 10:17 AM
