Results 1 to 8 of 8
Thread: Help needed: MFI linkage fix
    Luft gekuhlt Bummler's Avatar
    May 2005
    The Valley...
    On the drive home from Monterey I noted some stiffness developing in my throttle linkage and what felt like a "step" in the linkage.
    After getting home I traced the problem to the bell crank (deflection lever) at the back of the motor which connects the throttle rod emerging from the fire wall connecting to the deflection shaft. The bushings on the bell crank apparently have failed.
    I've ordered the parts. My question is can I do this w/o removing the motor? Access is dicey and my hands and fingers are not as nimble as they once were.
    Advice and any photos of he actual crank, the back side of the motor, and how it all fits together much appreciated.
    Stefan Josef Koch
    RGruppe #194/SRegistry #1063
    2015 Porsche Cayman S
    Stefan, the car below is pretty dirty, but should help. The owner had to do the same thing you are looking at.
    Jack the car up onto high jackstands using a hydraulic jack. This will give fellas of our size more than enough room to easily move around underneath. An undercar rolling dolly is a big help, too.
    I just buy the cheap harbor freight stuff for low tech items like these tools (if you don't have them already).
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Also, here's an exploded view of the assembly from the PET.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Mar 2006
    Louisville KY
    The rod that the bellcrank uses is threaded into the trans. An 8mm wrench will loosen it to remove it then you can take it all off in one assembly.
    Tony Proasi
    52 split window coupe
    May 2005
    The Valley...
    Kenik thanks in advance for your help.
    The bell crank I was referring to is inside the engine compartment behind the #3 throttle body. A real pain to access especially when you have huge arthritic hands like mine. So I'll likely leave this one to the pros (Tony and Marco) at TLG...
    Be well...
    Stefan Josef Koch
    Even though you'll have the 'pro's' do this, the answer to your question is that you remove the injection stacks which greatly improves the access to the bellcrank. Then you can slide the bellcrank partly off the shaft (the shroud is in the way) and use new plastic bushings. The plastic will let you slit the inner bushing and slip it on the shaft. The outer bushing will slip on the shaft from the end in the normal fashion.
    May 2005
    The Valley...
    This option/method has been discussed... Thanks
    Stefan Josef Koch
    Junior Member
    Aug 2009
    North Carolina
    That is a challenging fix at the throttle body, I used the correct sized bronze bushing so I won't have to replace them again. The plastic will last a long time but the bronze is practically permanent. I think Performance Parts (Automotion?) has them and they are the same size as the bushings at the pedal bell crank which is included in the pedal bushing rebuild kit. The tranny bell crank uses the same size as well.
  1. WTB Weber linkage
    By Bill Harris in forum For Sale: 911 Parts
    Last Post: 05-22-2012, 09:59 PM
  2. Help needed- wiper linkage removal
    By mobius911 in forum Technical Info
    Last Post: 12-19-2007, 10:43 AM
  3. Genetic linkage
    By gruen911 in forum General Info
    Last Post: 11-08-2007, 04:23 PM
  4. Replies: 4
    Last Post: 07-23-2005, 06:43 AM
